Page 8 of 56 FirstFirst ... 67891018 ... LastLast
  1. Posts : 1
    WINDOWS 7
       #70
    THANK YOU THANK YOU THANK YOU
    YOU ARE A GOD OF ALL COMPUTER GODS. I SEARCHED HIGH AND LOW ON HOW TO FIX THIS PROBLEM UNTIL I CAME ACROSS YOURS. IT WORKED PERFECTLY STEP BY STEP AND YOUR INSTRUCTIONS ARE THE BEST. IT'S NICE TO SEE SOMEONE WHO TAKES THE TIME TO DO THINGS RIGHT THE FIRST TIME INSTEAD OF DOING IT HALF AZZED AND THEN HAVE TO DO IT OVER. THANK YOU FOR POSTING THIS. YOU SAVED MY PC AND ALL MY KIDS PICTURES. FIRST PRIORITY. DO A BACK UP OF ALL FILES AFTER THIS MESSAGE. THANK YOU.
    CHEERS AND HAPPY NEW YEAR TO YOU AND YOUR FAMILY.
  2. Posts : 12,177
       #71
    Glad to hear it worked for you.
    Let us know if you have any other questions.
  3. Posts : 4
    Windows 7 64 bit
       #72
    Do you reccomend a guide to do when the files at step 17 have ZERO bytes? Tried MANY methods but none have worked.
    ALSO, now the COMMAND PROMPT option does not show up!
  4. Posts : 72,052
       #73
    Hello Parga, and welcome to Seven Forums.
    If doing a system restore at boot using a restore point dated before this started doesn't help, then you may be looking at having to reinstall Windows 7.
  5. Posts : 1
    w7 64
       #74
    I just used this fix and it worked great and my system is up and runningnow. on the phone with tech support at Norton and Toshiba today and they were no help at all Thanks Again
    Don
  6. Posts : 12,177
       #75
    Welcome to Seven Forums darrowo.
    Glad to hear Dzomlija's tutorial helped you get your system running again.
    Let us know if you have any other issues or questions.
  7. Posts : 1
    Hi i have tried every option listed and am still unable to get out of the repair loop, I am not really that good with computers and would appreciate some help with my problem.
    Nothing seems to work have also tried every restore point available
    any ideas???????
  8. Posts : 2
    Vista 64 Bit
       #77
    Hi All,
    I was able to follow the instructions but it's still in a loop. I also tried the fix /bootrec method and it's not working as well.
    Some says to try booting in Safe mode but when I press F8 nothing happens.
    Any ideas?
  9. Posts : 4
    Windows 7 64 bit
       #78
    Hi Brink thankyou for the fast reply, Is there a guide to reinstalling windows? I have no problem seeing as i have my needy files on my USB, also the disc that it came with is labeled "Utilities & Drivers" so i do not know if that helps, i dont think so.
  10. Posts : 72,052
       #79
    Parga,
    It sounds like you have a OEM (store bought) computer. What brand is it, and is it a notebook/laptop or desktop? :)
