Page 17 of 56 FirstFirst ... 7151617181927 ... LastLast
  1. Posts : 24
    Windows 7 64bit
       #160
    Ok im still getting an error, so heres what im doing: Clicked advanced in the startup repair, then it says X:\windows\system32 users, so what do i do from there? I tried putting C: then entering defrag C: /R, but it says that it is not recognized
  2. Posts : 72,052
       #161
    What about at X:\windows\system32 instead.
    In addition, try defrag C: /F instead.
  3. Posts : 24
    Windows 7 64bit
       #162
    Nope it says 'defrag' is not recognized as an internal or external comand, operable program or batch file
  4. Posts : 72,052
       #163
    Hmm, ok.
    Start over. When the command prompt at boot first opens at X:Sources>, type C: and press Enter. C would be the drive letter for the Windows drive at boot.
    You should then see C:\Windows\System32>. If not, the C may not be your Windows drive letter at boot.
    If you see that path, then Defrag C: /R should work. It will take a while to complete until the prompt reappears again.
  5. Posts : 24
    Windows 7 64bit
       #164
    The command prompt doesnt start off at X: sources, it starts at X:\sources\system32
  6. Posts : 24
    Windows 7 64bit
       #165
    When i did the diskpart thing, it shows the C: is OS and E is recovery is that something im doing wrong?
  7. Posts : 72,052
       #166
    See if using the tutorial below to open the command prompt at boot will open to X:\Sources like below.
    Command Prompt at Startup
  8. Posts : 24
    Windows 7 64bit
       #167
    It doesn't work, still get X:\windows\system32
  9. Posts : 72,052
       #168
    You might see if you may be able to do a system restore at boot using a restore point (if available) dated before this happened to see if it may help.
  10. Posts : 24
    Windows 7 64bit
       #169
    Nope, one of the first things I tried, doesn't work
