#170
I got it to defrag, by going to C:\windows\system32 then doing the defrag command defrag C: /R
Perfect. Now, to see if it will let you finish doing the tutorial on the first page when it's finished.
Hey Brink, well it is said invoking defragmentation on OS <C:> it said for an hour then blue screened
Ahh dang, is there any way i can get my files off the computer?
You may be able to use the tutorial below to recovery them.
https://www.sevenforums.com/tutorials...cy-backup.html
I re downloaded windows 7 and my computer crashed at around 50%. I now have the startup repair loop. I followed these easy steps however when I reached step 13, my RegBack only shows
0 files 0 bytes
2 Dirs 26,513,408 bytes free
I am so lost. Please help.
Btw I have had crashing issues in the past I think because of my motherboard.
Ps: I use 64 bit
Hello Spilled OJ, and welcome to Seven Forums.
Where did you get your copy of Windows 7 from? Sounds like a bad copy.
I got it from a comp USA store in nc 2 years ago.
The thing is I was going to sell my comp so I was just going to reinstall windows but I was too stubborn knowing my comp has very bad crashing issues ATM due to ram or motherboard issues. During the beginning stages of the download my comp crashed. I'm still hating myself for trying it. Idk if it helps but I did see the required folders under x:. Maybe the issue is I do not have the right files under c: d: or e:?
Or maybe the issue is I did the tutorial using x:? I did that because i also didn't have the right files for step 8 for my c: d: or e:
Yeah, the download is most likely corrupted. You'll need to have an uninterrupted download to use. You could download it from another computer if needed.
Did the computer come with Windows 7 preinstalled? If so, you should still have an OEM factory recovery partition that you may be able to use reinstall Windows back to factory conditions. Post back with what brand and model the computer is, and I'll be happy to see if I can find instructions for how to.
