Page 29 of 56 FirstFirst ... 19272829303139 ... LastLast
  1. Posts : 3
    Uh, question?
    Ok, so I'm new to this forum and not all that computer smart. I can get around pretty well, but when it comes to the really technical stuff like this I'm totally lost D:
    So here's my question: This doesn't completely reset your computer/laptop to factory defaults, does it? I have some important files on my laptop that I haven't gotten the chance to backup yet, and my laptop got stuck in this startup repair loop and I'm worried I'll lose my files if I try to fix it.
  2. Posts : 72,062
       #281
    Hello Max, and welcome to Seven Forums.
    No worries. This will not delete or reset Windows or your files. :)
  3. Posts : 3
    Ok thank you so much!
  4. Posts : 72,062
       #283
    You're welcome. :)
  5. Posts : 3
    Ok so I followed the steps but when I clicked "restart" it was like nothing happened! The computer looped back into startup repair and failed again. Is there something I'm missing? Do you have to repeat the process multiple times?
    Sorry if I'm being annoying
  6. Posts : 6,830
    Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
       #285
    maxwolfwing
    Run the tool below . Once done create a new thread inside System Security and upload the FRST.txt file and the Addition.txt
       Warning
    You will need a USB FLASH DRIVE
       Tip
    Download the Tool from a non infected PC
    Download Farbar Recovery Scan Tool
    Choose one that goes with your OS bit version Save the file to the Flash drive
    32-bit Version OS Farbar Recovery Scan Tool
    64-Bit Version OS Farbar Recovery Scan Tool x64
    Click the button and right-click Computer .Select Properties . Look for System Type: which will say 32-bit Operating System or 64-bit Operating System
    Plug the flash drive into the infected PC.
    Enter System Recovery Options.
    To enter System Recovery Options from the Advanced Boot Options:
    Restart the computer.
    As soon as the BIOS is loaded begin tapping the F8 key until Advanced Boot Options appears.
    Use the arrow keys to select the Repair your computer menu item.
    Select US as the keyboard language settings, and then click Next.
    Select the operating system you want to repair, and then click Next.
    Select your user account an click Next.
    To enter System Recovery Options by using Windows installation disc:
    Insert the installation disc.
    Restart your computer.
    If prompted, press any key to start Windows from the installation disc. If your computer is not configured to start from a CD or DVD, check your BIOS settings.
    Click Repair your computer.
    Select your user account and click Next.
    On the System Recovery Options menu you will get the following options:
    Startup Repair
    System Restore
    Windows Complete PC Restore
    Windows Memory Diagnostic Tool
    Command Prompt
    Select Command Prompt
    In the command window type X:\FRST.exe (for x64 bit version type X:\FRST64.exe) and press Enter
    Replace letter X with the drive letter of your flash drive.
       Tip
    Type the commands below to see what your letter is for the USB drive and press ENTER after each command
    Diskpart
    List volume
    The tool will start to run.
    When the tool opens click Yes to disclaimer.
    Press Scan button.
    FRST will let you know when the scan is complete and has written the FRST.txt to file
    Please copy and paste both logs in your reply.(FRST.txt and Addition.txt)
  7. Posts : 5
    Windows 7 not sure how to find the bit
       #286
    Help?
    In the Regback file i think it was called...
    i couldn't find the hive programs which worries me. When i tried the next step i couldn't
    Please help?
  8. Posts : 6,830
       #287
    Khanh welcome to SevenForums
    See if you could do Post 286 .
    Upload those two files that will be inside the flash Drive after you run the Farbar Recovery Scan Tool .
    Files : FRST.txt and Addition.txt
  9. Posts : 5
       #288
    When i insert the flashdrive and go to command prompt i type in F:\FRST but it replies "the device is not ready."
  10. Posts : 6,830
       #289
    Basic Input/Output System is where you could change the settings of varies hardware . Like boot options , memory settings , over click a CPU and memory .
    If you could get Repair Your Computer when you press F8 you don't need the BIOS .
