Page 33 of 56 FirstFirst ... 23313233343543 ... LastLast
  1. Posts : 1
    Hi Everyone,
    As mentioned in step 13, what is the alternative method to use if all the files are 0 bytes.
  2. Posts : 72,063
       #321
    Hello Vaishnavi, and welcome to Seven Forums.
    Usually, you could try these options:
    A system restore at boot using a restore point (if available) dated before this happened.
    If that fails, then you may need to reinstall Windows 7.
  3. Posts : 1
    Windows 7 Home 64 bit
       #322
    Any hope?
    I have the startup repair offline issue.
    The Problem Signature reads:
    Event Name - StartupRepairOffline
    01 - 6.1.7600.16385
    02 - 6.1.7600.16385
    03 - unknown
    04 - 21200614
    05 - AutoFailover
    06 - 58
    07 - CorruptFile
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 1033
    Wisely or not, I've done the following:
    bootrec.exe /fixmbr
    bootsect.exe /nt60 all /force
    attrib -h -s E:\boot\BCD
    del E:\boot\BCD
    bootrec.exe /rebuildbcd
    No luck, so I tried;
    bootrec.exe /fixmbr
    attrib -h -s D:\boot\BCD
    del d:\boot\BCD
    bcdedit /createstore D:\boot\bcd.temp
    bcdedit.exe /store D:\boot\bcd.temp /create {bootmgr} /d "Windows Boot Manager"
    bcdedit.exe /import D:\boot\bcd.temp
    bcdedit.exe /set {bootmgr} device partition=D:
    bcdedit.exe /timeout 10
    attrib -h -s D:\boot\bcd.temp
    del D:\boot\bcd.temp
    bcdedit.exe /create /d "Microsoft Windows" /application osloader
    bcdedit.exe /set {c0dfc4fa-cb21-11dc-81bf-005056c00008} device partition=D:
    bcdedit.exe /set {c0dfc4fa-cb21-11dc-81bf-005056c00008} osdevice partition=D:
    bcdedit.exe /set {c0dfc4fa-cb21-11dc-81bf-005056c00008} path \Windows\system32\winload.exe
    bcdedit.exe /set {c0dfc4fa-cb21-11dc-81bf-005056c00008} systemroot \Windows
    bcdedit.exe /displayorder {c0dfc4fa-cb21-11dc-81bf-005056c00008}
    Now, I do have a slightly different boot screen. Before this, the "flying windows" did not show on boot. Not it does. However, still going to the startup repair loop.
    So I tried this;
    No luck...
    I've run the Western Dig HD diags and no errors are reported.
    I've run Farbar and have the log file, if anybody want to take a peek. It's big though and will take a few posts.
    Considering Kaspersky Rescue Disk 10 as a next step, but will not do anything until, I hear back from you guys...
    Anybody have any ideas?
  4. Posts : 1
    I have tried and failed everything I've found in this thread. Reinstalling windows fixes the issue, but it comes back in a week. Any ideas?
  5. Posts : 14
    Windows 7 Pro 64bit
       #324
    So glad I found this procedure. I was hung in a "do loop" with Startup Repair until I followed this solution. Worked great for me!!! I have recovered my OS and data.... Whooopee! Only took me 11 days of sweat and struggle to find this fix.
  6. Posts : 2
    windows7 home premium 32 - bit
       #325
    didn't work :(
    Hi I'm Duan, I have a custom build PC, windows home premium 32 bit, and I followed every step to the letter space and dot, but when I restart the startup repair screen pops up again... Please help me asap I need the information on my computer urgently, I might lose money if I don't get it on time! Thank you. Duan
  7. Posts : 72,063
       #326
    Hello Duan, and welcome to Seven Forums.
    For now, you might see if you may be able to use a bootable Peppermint live DVD/USB to get the files you need off your PC.
    https://www.sevenforums.com/tutorials...cy-backup.html
  8. Posts : 5
    Windows 7 Ultimate 32bit
       #327
    Cannot Resolve the problem
    Hi...
    Im facing this problem when i changed my win7 32bit os to 64bit...
    I followed your steps..But i have 0 byte that u told in the 13th step..plz can u tell me what is the alternative method???
  9. Posts : 72,063
       #328
    Hello Mohammed Adeeb, and welcome to Seven Forums.
    Alternative methods would be a system restore or system image recovery.
    Hope this helps, :)
  10. Posts : 2
       #329
    I did download peppermint and rufus on a flash disk. I then put it in the problematic computer but it didn't boot the way it said it would, it just kept on going in the loop again... Any suggestions?
