#370
If you can't find the key, you have some options:
1) Ask Dell to send you recovery media. They will probably charge 15 bucks to send it.
2) There must be a recovery partition on there. It will contain a file called install.wim. You just need to Apply that wim to the existing windows partition. However, you can't do that from within the existing windows installation. You can do it if you can attach another machine, or if you boot up repair media and do it from there.
3) Install a free os. Linux Mint is popular. I am downloading Mate 64 bit as we speak. Download - Linux Mint
