Page 38 of 56 FirstFirst ... 28363738394048 ... LastLast
  1. Posts : 16,160
    7 X64
       #370
    If you can't find the key, you have some options:
    1) Ask Dell to send you recovery media. They will probably charge 15 bucks to send it.
    2) There must be a recovery partition on there. It will contain a file called install.wim. You just need to Apply that wim to the existing windows partition. However, you can't do that from within the existing windows installation. You can do it if you can attach another machine, or if you boot up repair media and do it from there.
    3) Install a free os. Linux Mint is popular. I am downloading Mate 64 bit as we speak. Download - Linux Mint
    searle said:
    I don't have a copy of the license key, so can't reinstall windows. It's a dell, I have everything I need off it but just have no way of activating it, came preloaded on the laptop with no stickers or anything with the key on. Looking for a fix as having to pay for another copy of windows isn't an option for me.
      My Computers
  2. Posts : 31
    Windows XP 32-bit
       #371
    Like Brink just stated, sometimes the Win Lic sticker is underneath the battery pack. You can follow SIW2's suggestion and call Dell to give you the Recovery Disks or a Windows 7 copy. They gave me a Windows 7 installation CD/DVD but I had to beg for it and I had no Warranty left on the system so I got lucky. I'm sure you still have the Dell System Tag number (don't you?), that could help in deciding whether they charge you or not for the Recovery Disks. Do you still have Warranty on that system or is it expired?
  3. Posts : 1
    Windows 7 Professional 64 bit
       #372
    G'day
    I need help desperately. I have followed the instructions to a T in the "Startup Repair Infinite Loop Recovery"
    I was previously able to go to System Recoveries Options now NOTHING it's really completely stuck in
    Startup Repair so I can even restore from an old backup, which I now know I should have done.
    Any ideas???
  4. Posts : 36
    Windows 7 Pro- 32bit.
       #373
    I think you need to get out of all of it and start over... Hold down on the start button on the pc or laptop until the machine shuts down. Unplug the machine and wait 30 seconds and plug it back in and start it back up. See if you can follow the instructions again. I'm not sure if this will help but, it's worth a try at this point.
  5. Posts : 5
    Windows 7 Pro 64 bit
       #374
    Hello, all. I am in need of your help. I am running Windows 7 Pro 64bit. I have tried the Startup Repair Infinite Loop Recovery and it has been unsuccessful. When I get to step 10, I noticed that there is also a COMPONENTS.iobit, DEFAULT.iobit, SAM.iobit, SECURITY.iobit, and SOFTWARE.iobit. Are those supposed to be there? On step 13 my sizes are way off. My DEFAULT is 616,744, SAM 102,400, SECURITY 45,056, SOFTWARE 104,382,464, SYSTEM 25,976,832. I have also tried last known configuration, sfc scannow says I have errors but cannot repair them, running system repair 3 times, and all of the Bootrec.exe options. When trying to load windows, the Windows Boot Manager says the File: WDFLDR.sys Status: 0xc000000f failed to load because a required file is missing or corrupt. I would like to do a Windows Repair install but to use the "upgrade" option I have to be in windows to do it. I have an external case that I can put my corrupt SSD drive into, is it possible to run the Repair Install from a working system and repair the external drive when it is being used as a secondary drive? If that makes sense. Also, I am not sure when it happened but the Startup Repair disappeared after trying one of the options I have read online and I am now using a bootable USB drive of Windows to use the Startup Repair utility. Any and all help will be greatly appreciated!
  6. Posts : 72,050
       #375
    Hello MilkMee6,
    If you have not already, you might see if doing a system restore at boot using a restore point dated before this happened may be able to help.
    Hope this helps for now, :)
  7. Posts : 5
       #376
    Thank you for the response but I have already tried that and there are no System Restore points to rollback to. Any other ideas besides having to do a format and clean install? Will putting the corrupt drive into an external case allow me to run a repair install from another computer?
  8. Posts : 72,050
       #377
    I'm afraid that wouldn't work for a repair install. It must be upgraded from within the running OS you want to repair.
    As a test, see if you may be able to boot into Safe Mode, then use the tutorial below to troubleshoot with a clean start to see if you may be able to boot into Windows afterwards. If so, then you may be able to continue with the tutorial below to find the culprit to fix instead of doing a repair install.
    Troubleshoot Application Conflicts by Performing a Clean Startup
  9. Posts : 5
       #378
    Ok thanks. I am unable to boot into safe mode. When I run Startup Repair I receive two errors. msisadrv.sys is corrupt, Error Code = 0x2. And wdfldr.sys is corrupt. I copied those two files from another Windows 7 64bit OS and put them on my corrupt drive and it gave me the error code listed above. Any other way to fix these two corrupt files?
    Update - Trying to start windows, windows boot manager now gives corrupt file ksecdd.sys.
  10. Posts : 72,050
       #379
    Looks like it may be time to reinstall.
