Page 41 of 56 FirstFirst ... 31394041424351 ... LastLast
  1. Posts : 1
    windows 7 eternity 32 bit
       #400
    Hey! For the first time I've experienced this startup issue on my laptop. I followed every step here but after restarting it, I was brought again to the startup repair page. In short nothing happened and now I fear that after performing this I might lose all my files. Why is that? I don't have any cd disk drives or dvd or whatever is that and I turned my system restore few months ago. Is there any way to open my laptop and get my files? I feel so desperate now. Help pls.
  2. Posts : 2
    Windows 7 Home Premium
       #401
    0 bytes help me
    Hello I am here because I am in need of some help. I own a XPS 9100 dell computer. A couple of days ago I tried to do a system restore because I was getting to many blue screens error. I did the dell data safe emergency recovery option, with no disk. Now I have the problem of the infinite loop. I followed this guide until the step to check how many bytes in each folder. I have 0 bytes all 5 folder which are DEFAULT through SYSTEM. Please help me. I don't want to give up on this computer.
  3. Posts : 5
    One big problem.... For me there is no "View advanced options for system recovery" and so on.
    So what do I do I can't do anything but sit there watch my pc do loops, I AM GOING INSANE
  4. Posts : 72,037
       #403
    Hello Jadi, and welcome to Seven Forums.
    Are you booting from your retail installation DVD/USB or system repair disc?
  5. Posts : 5
    Thanks for your reply, I believe I am not although I'm running from my original HD that has windows installed ... If it helps I was being kind of stupid with it and pressed the reset button AKA the button above the power button on the front panel multiple times... After I got frustrated about something.
  6. Posts : 2
       #405
    FIXED
    Well, I had this problem with my computer and I thought my computer was never going to be fixed. I came to this sight seeking for help and I got none, well anyways they way I fixed my computer was by calling Dell and asking for a DVD that was for reinstalling Windows. Pretty much I made a new reinstall of windows 7 home premium. I selected the CD/DVD boot option by pressing F12. If the CD/DVD option seems not to work turn off the computer and try it again, it didn't work for me the first time. My computer had 0 bytes also. Well help this helps someone.:)
  7. Posts : 1
    Windows 7 Professional 64 bit
       #406
    Thank you for this, I was facing a clean install all its attendant problems and losses but this fix worked well for me.:)
  8. Posts : 1
    It was like surgeon simulator, it was so scary. But it worked. Traumatic, but effective!
  9. Posts : 3
    Windows 7 Home Premium 32bit
       #408
    Good day, everyone!
    I have one question.
    I had created a Registry Backup by using Regedit > Export.
    Now my computer have this infinite loop error.
    How can I use the backup that I created earlier to fix the corrupted registry?
    Because one of the files in my RegBack folder is 0 bytes.
    Thanks in advance!
  10. Posts : 72,037
       #409
    Hello klv12gcn, and welcome to Seven Forums.
    You could use the method in the tutorial, or see if you may be able to do a system restore at boot using a restore point dated before this happened may help. :)
