#430
keyboard and mouse
hi thanks for this tutorial it worked a treat but on startup my keyboard and mouse do not respond so cannot put in password it is the same in safe mode any help would be great thanks
Hello Wessy, and welcome to Seven Forums.
If these are connected by USB, then double check your BIOS settings to enable any "USB at boot" type settings, and save and exit BIOS.
If you have an older PS/2 type keyboard or mouse, you will also be able to connect and use them at boot for now.
thanks brink but tried ps2 keyboard and that not work either
Restart the computer with the PS2 keyboard connected for it to be recognized, and see if it may work then.
thanks again brink but tried this no joy the keyboard and mouse do light up but no response
Ok I've got the bsod I've done the command got to reg back up
And now saying files cannot be copied onto self
Done the copy *.* space in between both still
Saying can't copy onto its self ?
Dzomlija THANK YOU so much.
I have been working on my computer for 3 days getting advice from the 3 different forums.
I finally did a search for the "problem signature 06" and found this.
I had tried everything and couldn't fix my startup problem.
Then I found this thread and in 2 minutes I was up and running.
Almost missed it though. The first time I didn't see the .. hidden files after the copy all command.
Went back and read it again. added the .. and that easy. It started right up.
THANK YOU, THANK YOU. THANK YOU.
So I just HAD to register and log in to say : Thanks for all your help from another grateful ex-sys admin who's current technique is google-ing everything.
Kindest regards
Keep up the great (and largely thankless) work.
Kal
I followed that tutorial and still can't seem to bypass the system recovery. The computer I have is a custom built one and the hard drive was used before by me and it had viruses before I put it in storage becuse my gpu was blown. I'm trying to get it to start with said HD because it's all I have and desperately need this computer up and running. I can't seem to find my Win7 Disc so can't do a full restore or I'd have done so already.
How can I get this to start up properly? Pressing F8 doesn't do anything either since it just says it failed to startup recovery and restarts instantly. What is wrong?
