Page 51 of 56 FirstFirst ... 414950515253 ... LastLast
  1. Posts : 16,163
    7 X64
       #500
    The sizes sound OK.
      My Computers
  2. Posts : 7
    Windows 7 Home Premium SP1 64-bit Build 6.1.7601
       #501
    SIW2 said:
    The sizes sound OK.
    Thank you so much for replying! :)
    They do?!? Really?!? Hmmmmm....
    That's not what the instructions say.
    Nice quotes btw...
  3. Posts : 1
    Hi
    I make all the steps but when i make the 13 my pc give me the info i have 0 bytes. what i can do for fix this problem?
  4. Posts : 2
    Windows 7 32 Bit
       #503
    hi guys having the same issue as most of you, tried this fix didn't work at all....any ideas on what else i can do?
    Cheers in advance
  5. Posts : 1
    Windows 10 Home x64
       #504
    I know I'm not even nearly the first to, but I just had to sign up to this forum to give many, many thanks to the original poster for this solution.
    Windows Start-up Repair wouldn't work.
    System Restore wouldn't work.
    Checkdisk wouldn't work.
    System File Checker wouldn't work.
    Repairing the Boot Manager wouldn't work.
    A few other things wouldn't work.
    This was literally my last throw of the dice. I'm so happy that I persevered and that my Google Fu skills were strong.
    So thanks again Dzomlija.
  6. Posts : 5
    Urgent help!!
    I used your method two times when the computer looped like that and they worked each time. It started looping again and when I click on "Advanced options.." I only have startup repair in the recovery tools. Help!!
  7. Posts : 5
    andrewcr said:
    After I click step 5, there is no command prompt option in step 6. Only shows 2 recovery options: Startup Repair and Dell DataSafe Restore.
    I have this too. Only startup repair tho. Any luck?
  8. Posts : 16,163
    7 X64
       #507
    Press shift+F10 when you are at the startup repair option.
      My Computers
  9. Posts : 5
    I did that but nothing comes up
  10. Posts : 5
    It doesn't work, is there anything else I can do? Please I need to fix it.
