Page 54 of 56 FirstFirst ... 445253545556 LastLast
  1. Posts : 1
    Windows 7 x64
       #530
    Heyroodean76 said:
    I have an additional line after Default, Sam, Security, Software, system which is " SYSTME" with 0 bytes. Which is not appeared on the posted screenshot in your tutorial. Any help will be appreciated.
    I have the same problem. Can someone help me?
  2. Posts : 1
       #531
    Help
    Is my file safe? I mean I want to keep all of my files
  3. Posts : 72,058
       #532
    Hello AbedTh, and welcome to Seven Forums. :)
    Your files will be safe while doing the steps in the tutorial. They will not be deleted.
  4. Posts : 9
    Windows 10 Home
       #533
    Hello Brink. Thank you for the tutorials. Hey, I'm experiencing this problem on a machine I'm working on and have gone through this tutorial however there is no change. Any other ideas? Thanks!
  5. Posts : 72,058
       #534
    Hello MsBobina, and welcome to Seven Forums. :)
    You could see if doing a system restore at boot using a restore point dated before this happened may be able to fix it.
    System Restore - Windows 7 Help Forums
  6. Posts : 9
    Windows 10 Home
       #535
    Thanks Brink. I have tried that unfortunately the restore point wasn't far enough back. I found a post here: Windows 7 Help Forums Windows 7 help and support BSOD Help and Support » BSOD: 0x0000007b (0x80786B58, 0xC0000034, 0x00000000, 0x00000000) ---sorry, I don't know how to make it a link, but those are the same stop codes/numbers (not sure what they are called) that I get. The suggestion is to remove the drive from the machine that is getting the bsod and connect it externally to another machine and make certain changes to the registry however, there are no instruction on how to get to the registry from an external drive. Would you mind telling me how to do that?
  7. Posts : 9
    Windows 10 Home
       #536
    I will following the instructions from the other post on what changes to make to the registry. I can ask how to get there too if you want. I just figured since I started here I would stay here.
  8. Posts : 72,058
       #537
    Sure, that'll be fine to ask there or create a new BSOD thread for it.
  9. Posts : 9
    Windows 10 Home
       #538
    okie dokie thanks.
  10. Posts : 1
    Windows 7 home premium
       #539
    The only option I have to to restart my computer, it won't let me get to the command prompt. It won't even show the icon for it
