#530
Is my file safe? I mean I want to keep all of my files
Hello AbedTh, and welcome to Seven Forums. :)
Your files will be safe while doing the steps in the tutorial. They will not be deleted.
Hello Brink. Thank you for the tutorials. Hey, I'm experiencing this problem on a machine I'm working on and have gone through this tutorial however there is no change. Any other ideas? Thanks!
Hello MsBobina, and welcome to Seven Forums. :)
You could see if doing a system restore at boot using a restore point dated before this happened may be able to fix it.
System Restore - Windows 7 Help Forums
Thanks Brink. I have tried that unfortunately the restore point wasn't far enough back. I found a post here: Windows 7 Help Forums Windows 7 help and support BSOD Help and Support » BSOD: 0x0000007b (0x80786B58, 0xC0000034, 0x00000000, 0x00000000) ---sorry, I don't know how to make it a link, but those are the same stop codes/numbers (not sure what they are called) that I get. The suggestion is to remove the drive from the machine that is getting the bsod and connect it externally to another machine and make certain changes to the registry however, there are no instruction on how to get to the registry from an external drive. Would you mind telling me how to do that?
I will following the instructions from the other post on what changes to make to the registry. I can ask how to get there too if you want. I just figured since I started here I would stay here.![]()
The only option I have to to restart my computer, it won't let me get to the command prompt. It won't even show the icon for it
