Page 55 of 56 FirstFirst ... 4553545556 LastLast
  1. Posts : 1
    Windows 10 - 64 bit
       #540
    Great indications - it works on windows 10 also
    I have a lite version of windows 10, that I use for my work, working in a virtual machine under ubuntu.
    After a system update of virtualbox, windows wasn't able to start entering in an infinite loop of automatic repair.
    Following this guide, after 10 min. of timework I resolved.
    Thank you very mutch!
    Fabio
  2. Posts : 5
    windows 7
       #541
    question
    I am trying to do this but in step 13 the last line say
    DIR 0 bytes of free space. The other numbers are almost the same in the instructions. I can still do this if my hard drives has no free space? Do you know how I can free disc space to complete the procedure?
  3. Posts : 7,107
       #542
    Hi Eli21,
    ITS NOT saying not enough Disk space BUT NOTHING in the hive if its showing 0 , which it needs to complete the repair, hence the rider you will need to do it a different way
    Have you any re-install disks??. if so follow this tutorial
    Repair Install - Windows 7 Help Forums
    Roy
  4. Posts : 1
    64Bit Home Premnium
       #543
    Reg takeover!
    Just like to thank Peter for this very good info,because I had completely lost Windows.
    I persevered refusing to fresh instal Windows,and after 50 or maybe more restarting I actually was able to get into cmd prompt again,and so THANKS you are doing great work Peter.
  5. Posts : 1
    Windows 10 Pro
       #544
    Thanks!
    I've registered on the forum just to say thanks. I'm on Windows 10 Pro, got the infinite startup loop after windows update (I think). Spent hours trying google searched answers, stumbled on this thread, follow the steps, and it worked! Much appreciated!
  6. Posts : 1
    Thank you very much!
    I am yet another happy customer. This tutorial was perfect and fixed my problem without a hitch. Thank you so much!
  7. Posts : 4
    windows 7 home premium 64 bit
       #546
    i already had that loop problem some time ago, then used those commands, of the front page
    CD \windows\system32\config
    DIR
    MD mybackup
    copy *.* mybackup
    overwrite with A
    CD RegBack
    DIR
    copy *.* ..
    overwrite with A
    exit
    remove windows DVD and restart go to BIOS and select hard drive as boot device
    now it happens again
    when entering those commands i get this screen
    X is now the new boot drive, which is new to my knowledge
    I have double the amount of config files ? with .log endings
    And one of those rows show 0 Bytes, so i stopped with going on entering any further commands
    is this all just a mistake, and simply means nothing else than, that there is an already once created backup that i can use to restore
    sorry for the english, german native language
    someone in another forum posted to copy those files, in cmd command window, from the original windows DVD to the hard drive that windows is installed on and everyone was happy with the result, but i am not sure if i should do that, because i am confused as to why the boot drive is called X, why are there a double amount of config files with .log endings, and therefore how to behave in my case
    C:\windows\system32\config\regback\system c:\windows\system32\config\system
    C:\windows\system32\config\regback\software c:\windows\system32\config\software
    C:\windows\system32\config\regback\security c:\windows\system32\config\security
    C:\windows\system32\config\regback\sam c:\windows\system32\config\sam
    C:\windows\system32\config\regback\default c:\windows\system32\config\default
    Attached Thumbnails Attached Thumbnails Startup Repair Infinite Loop Recovery-cmd.jpg
  8. Posts : 16,161
    7 X64
       #547
    X is the winpe drive in RAM. Nothing to do with your hard drive.
    You need to locate your windows installation partition. It can be done via diskpart commands, or it is easier to type the following in cmd prompt:
    Notepad
    (then press enter)
    When notepad pops up, click File, then Save and you can use the browse dialog to browse your computer and get the drive letter that has been assigned to your windows partition ( it might not be C - don't worry, use the drive letter that you see in the browse dialog )
    Alternatively, you can use my boot media which includes windows explorer ( and lots of tools ) so you can see what you are doing:
    17514x86.iso
    17514x64-v10.iso
      My Computers
  9. Posts : 4
       #548
    ok going to try that
    1. should i be concerned about those double entries ? one time normal and a second time with .log endings
    2. and when i copy those commands from the windows dvd onto the hard drive
    for example the command:
    copy C:\windows\system32\config\regback\system c:\windows\system32\config\system
    i have to change the second c: in that command line, to the letter of my hard drive, right?
    3. i also got a "CRC" error message on drive D:
    thinking about to do that chksdk /f /r command first or those windows dvd copy files command onto hard drive
  10. Posts : 16,161
    7 X64
       #549
    copy ?:\windows\system32\config\regback\system ?:\windows\system32\config\system
    You need to use the letter of your windows partition for both the ? above. That is the letter as seen from your booted media
    It might be C, or it might be D or another letter. That is why you need to look to find the windows partition letter - as seen from your booted media.
    No - because they are on the X drive ( winpe drive) - they are nothing to do with your windows installation at all - completeley irrelevant.
      My Computers
