Hello Sope,
I would see if creating a shortcut, then set it to open minimized. Next, use the path to the shortcut in Task Scheduler instead.
Hello Sope,
Hi. I've got the same problem as Sope. But thru Windows live mail. Which doesn't have the option of always starting minimized.
I have it thru option 1 (Startup folder) opening at startup. and I have it in vista compatibility mode so that I can minimize it to the system tray.
I want it to start minimized to the system tray when i turn on my computer. Can anyone help with this?
Brink, when I google my questions, you always have the top answer and your always right, even with vista questions. I'm glad I found your windows 7 site. You are awesome man.
Thanks,
Kevin
