Startup Programs - Change
Page 17 of 18 FirstFirst ... 715161718 LastLast
  1. Posts : 476
    windows 7 ultimate 64bit
       #160
    in the past i used Startup Control Panel
    autorun looks to aggressive
    is there a tool safe to use?
  2. Posts : 72,052
       #161
    Hello Drugo,
    It depends on what you are wanting to do. If you are just wanting to enable, disable, or delete startup programs, then using CCleaner from OPTION FIVE is a good and easy choice to do so. :)
  3. Posts : 10
    Windows 7 64 bit Pro
       #162
    can i throw everything in the current user in the reg edit since im the only user since there are both all users and curent user start up ?? and vice verse the admin
  4. Posts : 72,052
       #163
    Hello PcWizKid,
    Sure if you would like to. :)
  5. Posts : 9
    Windows 7 64
       #164
    thank Shawn, very helpful
  6. Posts : 3,904
    Windows 7 Ultimate 64-bit
       #165
    Nice Write up brink :)
    Im sure this will help many people :)
    It has more than five million views!
  8. Posts : 3,904
       #167
    Brinks a popular man
  9. Posts : 1
    Joined sevenforums cause of this well explained post........thanks alot for posting!
  10. Posts : 21,004
       #169
    Actually if you want more then this one is just part of this tutorial Optimize Windows 7 it is my bible
