Startup Programs - Change
Page 3 of 18 FirstFirst 1234513 ... LastLast
  1. Posts : 72,043
       #20
    You're most welcome Kevin. Thank you for the kind words.
  2. Posts : 9
    Windows 7 Build 7100 32-bit
       #21
    Another great tutorial, I cant thank you guys enough, Ive learnt so much from this site, keep up the awesome work
  3. Posts : 72,043
       #22
    You're welcome Sam. :)
  4. Posts : 9
    Thanks Brink,it helps...
    but,actually i'm using ashampoo start up tuner 2..what a great tools for me..i just wonder why start up menu is not include inside control panel..
  5. Posts : 72,043
       #24
    Nudinsenin,
    The Statup programs list use to be availble to be changed in Windows Defender in Vista, but this option was removed in Windows 7 since Windows Defender is stricktly a malware program now in Windows 7. It would be nice for a user friendly GUI other than msconfig to change them.
  6. Posts : 9
    Brink said:
    Nudinsenin,
    Yeah,you right.It is easier i think.Actually,not 100% I explored Windows 7 after i installed it.
  7. Posts : 1
    windows 7
       #26
    Hi, I followed your way and find the startup list, however, I cannot find the program I want to start in the list, what should I do?
    Thanks.
  8. Posts : 72,043
       #27
    Hello Jihe, and welcome to Seven Forums.
    The program will not be listed unless it is already a startup program. Depending on what it is, you may be able to use METHOD ONE to add a shortcut of the program in the Startup folder to easily have it run at startup. :)
  9. Posts : 3
    all
       #28
    Yet again you have answered my question without me having to ask ......
    (My Linksys <Skype> phone was loading at startup and had no "options".
    I just HATE stuff that pleases itself! Now I click it's icon when I need it!)
    Thanks Brink.
  10. Posts : 72,043
       #29
    You're welcome Wazak. :)
