Gadgets not Displaying Correctly in Windows 7 - Fix
Page 1 of 12 12311 ... LastLast
    How to Fix Gadgets not Displaying Correctly in Windows 7
    If you have gadgets that are displaying on your Windows 7 desktop improperly as black, white, blank, or just messed up, then this will show you how to fix them.
    You must be logged in as an administrator to be able to do this tutorial.
    If you have a 3rd party firewall program installed, then also check to make sure that the gadgets are allowed in the firewall and are not being blocked in that program's exception settings.
    EXAMPLE: Gadgets not displaying correctly
    Gadgets not Displaying Correctly in Windows 7 - Fix-gadget-1.jpgGadgets not Displaying Correctly in Windows 7 - Fix-gadget-2.jpg
    OPTION ONE
    Automatically Using a BAT File Download
    NOTE: This does the same thing as in OPTION TWO below, but automatically.
    1. Click on the Download button below to download the file below.
    Reset_Gadgets.bat
    Download
    2. Click on Save (if prompted), and save the .bat file to your desktop.
    3. Right click on the downloaded .bat file and click on Run as administrator.
    4. If prompted by UAC, then click on Yes.
    5. You will see a command prompt flash open and close as the .bat file runs.
    6. When finished, restart the computer to apply.
    7. Check to see if the gadgets on your desktop are displaying correctly now. If not, then try uninstalling and reinstalling any gadgets that are still not displaying properly, or do a System Restore using a restore point dated before the problem.
    OPTION TWO
    Manually in an Elevated Command Prompt
    NOTE: This does the same thing as in OPTION ONE above, but manually.
    1. Open an elevated command prompt (right click - Run as administrator)
    2. In the elevated command prompt, copy and paste each command below and press Enter one t a time. After each time your press Enter, you will need to click on OK before doing the next command.
    • taskkill /im sidebar.exe /f
    • regsvr32 msxml3.dll
    • regsvr32 scrrun.dll
    • regsvr32 jscript.dll
    • regsvr32 atl.dll
    • Regsvr32 "%ProgramFiles%\Windows Sidebar\sbdrop.dll"
    • Regsvr32 "%ProgramFiles%\Windows Sidebar\wlsrvc.dll"
    • reg delete "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones" /f
    • "%ProgramFiles%\Windows Sidebar\sidebar.exe"
    3. Restart the computer to apply.
    4. Check to see if the gadgets on your desktop are displaying correctly now. If not, then try uninstalling and reinstalling the still bad gadget, or do a System Restore using a restore point dated before the problem.
  1. Posts : 1
    64 HOME PREMIUM
    thanks
    OH MAN!! thanks a lot lot lot lot, ive been looking for this solution since a long time ago, i was thinking of reformating my laptop but thanks to you now i dont have to do that really i appreciate your help. keep doing that
  2. Posts : 3,302
    Will this work on 64 bit systems to Shaun
    Thanks Danny
  3. Posts : 72,079
    Hello Danny,
    Yes, it will work on both 32-bit and 64-bit Windows 7. :)
  4. Posts : 8
    Win7 Professional - lited edition & Zorin OS 4 (ubuntu)
    Very nice, Brink...
  5. Posts : 1
    winows 7 ultimate 32bit
    thank you soooooooo much it 100% worked :)
  6. Posts : 72,079
    You're most welcome Soussisissou, and welcome to Seven Forums. :)
  7. Posts : 1
    Windows 7 64 bit
    Thanks so much
    Thank you so much. This worked like a charm.
  8. Posts : 72,079
    You're most welcome ThinkTankInk, and welcome to Seven Forums. :)
  9. Posts : 1
    Windows 7 Ultimate x32
    Thanx so much it worked excellent:)
