Gadgets not Displaying Correctly in Windows 7 - Fix
Page 2 of 12 FirstFirst 1234 ... LastLast
  1. Posts : 72,150
    You're most welcome Javeedulla, and welcome to Seven Forums. :)
  2. Posts : 1
    Windows 7 Ultimate x86
    The default gadgets have turned invisible and black
    Reset_Gadgets.bat Worked
    THANK YOU SO MUCH, IT WORKED LIKE A MIRACLE,
    I tried a lot of work like "SFC /SCANNOW Command"
    and many like this, but no one did not work.
  3. Posts : 72,150
       #12
    You're most welcome Amirhs, and welcome to Seven Forums.
  4. Posts : 6
    Windows 7 Home Premium 32bit
    Repair Gadgets
    I would also like to thank you for your help. Can you please tell me if this .bat will
    repair any gadget that I install? I am having trouble with a Kaspersky gadget and I
    have tried explaining and I have sent a screenshot. Their answer is reboot. This gadget is very usefull for shortcuts to various parts of the antispyware software. Reboots each time is a nonstarter. Thank you again from me in the UK.
    Best wishes D.Hughes
  5. Posts : 72,150
       #14
    Hello D.Hughes,
    The .bat file doesn't fix the gadgets themselves, but only resets and re-registers the gadget settings and permissions back to default in Windows 7 to hopefully allow the gadgets to run properly afterwards. It's worth a try to see if it may help though.
    If their is something wrong with the gadget itself, then only the publisher (ex: Kaspersky) can fix it with a update or new release of it.
  6. Posts : 2
    windows 7 ultimate 64bit
       #15
    MANY MANY THANKS
    Your excellent batch file worked !!!
    Thank You
    God bless YOU i was very of it;
  7. Posts : 72,150
       #16
    You're most welcome Renal, and welcome to Seven Forums. :)
  8. Posts : 6
       #17
    Brink, I am back again.Could you please help. I do not know how to program but this is what I would like to do. I have put a shortcut on the quick launch bar which runs your fix, however the CMD window stays open. I have tried typing EXIT at the end but this does not seem to close the cmd window. I have tried it in other places but because I do not know what I am doing I stopped. If you can please help.
    Thanks again from UGGY from a cold and wet North Wales.
  9. Posts : 72,150
       #18
    Hello Uggy,
    Are you using the BAT file download? Normally you could just close a CMD window like any other window by clicking on red box X at the top right corner of the window.
    Could you post a screenshot of the CMD window showing what it's saying inside to see if something may have went wrong?
  10. Posts : 6
       #19
    Gadet Repair
    Hi Mr Shawn Brink how are you? I think I confused everyone.What I have done is to download the Auto not manual .bat. I have Pinned a shortcut to the Quick launch bar and what I wish to do is- Click on the shortcut make the program run without any input from me then close itself when it has completed the task. I tried putting exit or end as the last line but nothing happened. I do not know enough about MS-DOS commands to make this work. Could you please help? Thank you again for all your help.
    Best wishes UGGY.
