#30
Hello Blackwolf, and welcome to Seven Forums.
What issue are you having with gadgets?
Is this a issue with one or all gadgets including the default ones that came with Windows 7?
If only one, which gadget is it?
Sample;
https://www.sevenforums.com/gadgets/1...-pls-help.html
My desktop;
Blackwolf,
Are you using the one from the links below? It works fine for me, but does not show up in Gadgets like it does in your screenshot.
(home page)
Processors — Intel® Turbo Boost Technology Monitor overview
(download page)
http://downloadcenter.intel.com/Deta...19105&lang=eng
In that case, you might see if the one below may work for you. It does for me. Be sure that you have Turbo Boost enabled for the CPU in BIOS though.
Intel TurboBoost Monitor Software Version 1.0.186.6
However, you would be better off using the latest version in my post above though.
I'm afraid that you may have to use the 2.0 version now since it appears to have fixed whatever issue the older version does't work for you.
