#70
I'm using Eset 6 and its firewall is off. I'm using Windows Firewall. There are no other applications for firewall.
All the windows gadgets are not working and any gadget i install like daemon tools gadget, tune up gadget none of these are working.
If you have a restore point dated before this happened, you could do a system restore to hopefully fix it.
Otherwise, you may need to either reinstall or do a repair install.
Have this problem from a long time. Didn't recognize it to be a problem. So, restore not possible.
And if i go for a repair install will all my applications be retained including documents where saved files of games and some applications get stored.?
Your programs and user folders will not be affected by a repair install.
However, I would always recommend to back up anything that you do not want to lose first just to be safe. In this case, creating a system image first would be ideal to be able to do a system image recovery with it if needed.
Hi All Me Test In Win 7 x64 Ul Not Work.
Plz Help M.
Thanks A Lot.
Hello AhrimanSefid,
Could you provide some more details, and what gadgets are not working? :)
Me Add Gadgets & Image For Error.
Plz Help Me.
Thanks A Lot.
