#80
Me Only Anti Virus Avast.
thank you so much now my gadget shows on hte desktop but i have a problem that my calernder look black no number on it, how ca i get the number back please need help
Hello Adla, and welcome to Seven Forums.
Do you have a 3rd party firewall program installed?
If so then double check to make sure that the gadget is allowed.
Me Remove All Gadets And Rest Win Add gadets Fix Error.
Thanks A Lot.
I just used the .bat, Brink, posted and it fixed my Gadgets, much love, Brink.
Hello Jack, and welcome to Seven Forums.
As a test, you might see if turning off and on the "Windows Gadget Platform" may help reset it to work properly again.
Gadgets - Turn On or Off
Hope this helps, :)
