#90
Thanks for the reply, ive tried this also still the same.
In that case, you could do a system restore using a restore point (if available) dated when they did work properly.
If that's not an available option, then you might consider doing a repair install.
Hi!!! I just regged here to be able to respond and say a BIG THANK YOU! The bat file worked excellent!
Thanks Brink this worked for me too. I didn't have to restart first they appeared straight away once the .bat file was run.
Not sure why it happened in the first place so it may occur again but at least I now have a fix.
Regards and thanks
I really missed having my gadgets and this fixed it, thank you!
Tried this after puzzling over missing gadgets following windows update & IE11 install, it work a treat, many thanks...
Thanks a lot Brink, for the batch file!
That worked for me too. My gadgets had disappeared, and couldn't activate or access any gadgets related menu. Had to do RightMouse > View > "Hide desktop gadgets" and then RightMouse > View > "Show desktop gadgets" after restart, and now all is OK again.
Thank you for posting you .BAT file. It worked splendidly and now all is well. Ivan.
