Hard Drive - Turn Off Hard Disk After Idle or Never
Page 5 of 6 FirstFirst ... 3456 LastLast
  1. Posts : 7
       #40
    Hey Brink:
    I used to have a 1GB HDD connected when I originally installed the SSD, but just long enough to get my data off of it. Now the only hard drives I have are the internal Samsung 850 EVO 500GB 2.5-Inch SATA III Internal SSD and an external Seagate 500 GB backup drive.
    The problem is that if left unattended, the computer completely powers down after ~ 20 - 30 minutes and must be restarted by hitting the power button. Prior to this, all we had to do was shake the mouse and it would wake up to the logon screen.
  2. Posts : 72,055
       #41
    The computer powering down would be a different setting than what this tutorial is for. This tutorial is only for the HDD itself and not the computer.
    Check using the tutorial below to see if you have set your power plan to put the computer to "sleep" or "hibernate" after being idle for that time.
    Power Plan Settings - Change
    Next, check to see if you mouse is still allowed to wake up the computer.
    Devices - See Devices that are able to Wake Up the Computer
    Devices - Allow or Prevent to Wake Up Computer
  3. Posts : 7
       #42
    All my power plan settings are configured as indicated, and both the mouse and keyboard are allowed to wake up the computer. Oddly, when I pull up Advanced Power settings I don't have the "Change settings that are currently unavailable" even though I ran powercfg.cpl as an administrator?
    Lastly, for some reason I don't have the battery options as described, despite having a Cyberpower UPS installed and (apparently incorrectly) configured?
    Hard Drive - Turn Off Hard Disk After Idle or Never-power-options-screenshot.jpg
    Hard Drive - Turn Off Hard Disk After Idle or Never-wake_computer_screenshot.jpg
  4. Posts : 72,055
       #43
    Paul,
    It appears that the "Turn off hard drive" setting is not your issue.
    I see that you have "Hybrid sleep" turned on. Do you have "Sleep" or "Hibernate" set to let the computer sleep or hibernate after being idle for x amount of minutes?
    It does show that your mouse should be able to wake the computer from sleep or hibernate.
  5. Posts : 7
       #44
    Brink:
    Yes, the computer is set to go to sleep (hybrid) after 30 minutes. Hibernate is set to never. The display is set to turn off after 15 minutes (not that this setting has anything to do with what you and I are looking for).
    When the sleep function was working properly, i.e. putting the computer to sleep after 30 min., a simple shake of the mouse or tap on the space bar would awaken it. Now - not so much...
    I appreciate your persistence.
  6. Posts : 72,055
       #45
    It appears everything is set properly so far for what you are wanting.
    One more thing to check is to see if you have a wake by USB type setting that may no longer be enabled in your BIOS settings.
  7. Posts : 7
       #46
    Brink:
    Sorry it took me so long to reply. Too many hours at work.
    I checked the BIOS settings and all ar as originally configured.
    Given that we've checked everything is it safe to assume my Windows installation has been corrupted? (Unless you have other suggestions...)
    Would "Reset this PC" to reinstall the OS be too drastic a move? If not, how can I do so with minimal needed reconfiguration afterwards? I've never done this since I've only had Windows 10 for a few months.
    Thanks - Paul
  8. Posts : 72,055
       #47
    You could do a repair install of Windows 10 to see if it may help without losing anything.
    Repair Install Windows 10 with an In-place Upgrade - Windows 10 Installation & Upgrade Tutorials
  9. Posts : 89
    Win 7 x64
       #48
    ignatzatsonic said:
    I assume it has to do with the fact that SSDs have no moving parts and therefore can't "spin down" to save power. They are either in use or not in use---on or off.
    Brink said:
    Yep, that would be why. :)
    Alright, 10x guys! :) I was under the impression that 'Turn Off Hard Disk' affects SSDs as well, but I see you're suggesting the opposite.
    This here (SSD W7 Power options? - The Corsair User Forums) suggests that 'in windows 7 under power settings the "turn off hard disk after _ minutes of inactivity" only applies to your primary drive. ALL other drives will spin down at some point regardless of what you change this setting to'.
    This here (Power Settings Adjustment - Can You Get More Space Or Speed From Your SSD?) suggests that setting it to 0 i.e. never 'allows the SSD's idle garbage collection to operate, even when you're not in front of your computer'.
    A few other sources I have that also back this claim. Where's the truth then?
    If indeed the 'Turn Off Hard Disk' doesn't affect SSDs then what do I do on my laptop that has 2 slots with 1 being my OS SSD and the other being my storage HDD? What 'Turn Off Hard Disk' setting would make most sense for my HDD, being used only for storage?
  10. Posts : 72,055
       #49
    Hello soewhaty, :)
    From my understanding and what I've seen, this has never affected SSDs, and has only affected any connected HDD. This doesn't always affect HDD's in a connected external enclosure though.
