Jumplist Launcher - Create Custom Jump Lists
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. Posts : 119
    Windows 7 Ultimate
       #30
    When I run 7.2, I click save and nothing comes up asking you to "create jumplist"; so I can't save it. What should I do first? Do I have to run the launcher or can I have a icon on the taskbar to run a jumplist from?
    What version are you using? John
  2. Posts : 134
    Windows 7 64-bit Windows 7 32-bit
       #31
    the jumplist is the program, you create a shortcut for it on your taskbar
  3. Posts : 41
    win7, vista
       #32
    can you change the icon of the jump-list program?
  4. Posts : 119
    Windows 7 Ultimate
       #33
    Multiple Instances of JL
    can One have jumplist launcher running multiple times on the same computer?
  5. Posts : 521
    Windows 7 Ultimate x64 Service Pack 1
       #34
    Sure you can. Simply right click on the pinned icon. Then right click JumplistLauncher. Open up properties and you can easily change it from there.
    I don't think so as you can only pin a program in your taskbar once if I'm not mistaken.
  6. Posts : 119
    Windows 7 Ultimate
       #35
    can I have two jumplists pinned on the taskbar? Made with jumplist launcher? John
  7. Posts : 521
       #36
    I tried making a copy of the JumpList Launcher folder and placing it in a different place on my PC, when I opened the JumpList Launcher from there, it showed another icon. However, I could not pin that. Maybe you can just set it to autostart minimized.
    However, you'll have a highlight indicating that it's simply minimized.
  8. Posts : 119
    Windows 7 Ultimate
       #37
    I am still having the problem with jumplist-launcher, that the button that says "create jumplist" does show up. Do I have to run it as a administrator?\
    John
  9. Posts : 521
       #38
    John
    Do you mean to say the button that says Update Jumplist?
  10. Posts : 119
    Windows 7 Ultimate
       #39
    this button
    this button!
    Attached Thumbnails Attached Thumbnails Jumplist Launcher - Create Custom Jump Lists-jumplistlauncher2.png
