Jumplist Launcher - Create Custom Jump Lists
  1. Posts : 14
    windows 7 build 7232 x64
    well...jumplist doesn´t disapear anymore after log off or restart...good job.
    But i think number of jump-list itens of 'Jumplist Launcher' should be independent from number of recent itens to display in jump lists of windows...i had zero itens to display in recent itens of windows, now i must have 12(there are the number of itens of 'Jumplist Launcher') in recent itens of windows so that 'Jumplist Launcher' works correctly.
    If you could correct this, that will be great.
    edit: i´m on build 7232 x64
  2. Posts : 42
    Windows 7 RC1
    Strange thing is I didn't change anything about that in version 2.
    In the RC (build 7100) that's impossible because Micro$oft unified both attributes.
    I dunno about newer builds.
    In the beta it was handled differently as far as I can remember.
  3. Posts : 14
       #12
    ok...didn´t know that.it seems on newer builds those attibutes are unified.
    congrats for this application, i like it.
  4. Posts : 23
    Windows 7 Ultimate 64 bit
    Great app, just wish I could have categories with my recent items option disabled. I'm forced to use the tasklist mode to prevent jumplist clutter in places I don't want it. Can't wait for the next update :)
  5. Posts : 620
    7264x64/7260x86
       #14
    I'm trying to do the following: Create a shortcut to virtual box with an attribute so I can launch a specific virtual machine instead of dealing with the gui.
    However anytime I try to add that shortcut to the jumplist launcher I get an error. Not sure what the error is but it appears to say something bout location not found.
  6. Posts : 43
    Win Seven Ultimate RTM
       #15
    Does somebody have the exe coz the dev site is down ??
  7. Posts : 124
    W7 64b - Leopard 10.6.2 - Ubuntu 10.10 (MBP Snow Leopard 10.6.3)
       #16
    Version 5 available...
    Great little app! Hope it keeps developing!
  8. Posts : 11
    I get the following error whenever I try to create a jump list with this tool:
    "Couldn't create the Jumplist. Please wait for the next update to fix this issue!"
    I'm running Windows 7 Ultimate x64 version. I also notice that the Max.Jumplist Items is greyed out with a default setting of 1 and it doesn't allow me to change it. So not sure what I'm doing wrong here. Any suggestions?
    PJStyles
  9. REB
    Windows 98 SE
       #18
    I always get that error.. What a retarded way to tell theres an error.. "wait for the next update"... he should make it say what the problem is -_-
  10. Posts : 4,573
       #19
    I agree. Then, you could develop a better program the right way.
