Transparency - Enable Full Clear Glass Transparency
Page 7 of 15 FirstFirst ... 56789 ... LastLast
  1. Posts : 8,476
    Windows® 8 Pro (64-bit)
       #60
    I m unable to take ownership of dwm. access is denied. also, when i directly try to copy and replace the dwm file, access is denied. i tried taking ownership manually but didn't work.
  2. Posts : 71,960
       #61
    Hello Dinesh,
    Did you do step 5 first to temporarily stop the service?
  3. Posts : 8,476
       #62
    Yes i did stop the service. When i right click on dwm, i dont have the take ownership thingy in the context menu. i tried to take ownership manually but didn't work. i was able to take ownership to the udwm.dll though.
  4. Posts : 71,960
       #63
    Double check to make sure that you have taken ownership and gave yourself full permission of the file. If you did, then try it in Safe Mode.
  5. Posts : 8,476
       #64
    Thanks a ton Shawn. It worked. :)
  6. Posts : 71,960
       #65
    You're welcome Dinesh. :)
  7. Posts : 149
    Windows 7 x64 RTM Retail
       #66
    Like others the registry entry ColorizationGlassReflectionIntensity ceased to work after a release of W7 (I forgot which one). Well I've been on the RTM for some time and at some point my caption bar became free of those diagonal stripes. DWM is from the RTM not a previous version.
    I recall that I tried back then adding the reg entry to no avail. However at some point my caption bar became clear. I didn't notice it until some time later.
    The other day I went into Personalize and all of a sudden the 'stripes' came back. The Reg entry was a 50 which is/was the default. I changed it back to zero, rebooted, but no change.
    I then selected the basic windows theme and viola the 'stripes' are gone again.
    So it's possible that adding the reg entry and changing to the basic theme will do the trick. You can then use your Aero theme again.
    Maybe this is particular to me. Your mileage might vary.
    Attached Thumbnails Attached Thumbnails Transparency - Enable Full Clear Glass Transparency-capture.jpg
  8. Posts : 158
    Windows 7 7600RTM X64
       #67
    Unfortunately it doesn't work for the Taskbar! The full transparency i mean, it'll removed the gradient, just not make it anymore "invisible."
  9. Posts : 29
    Windows 7 Professional (build 7600)
       #68
    Backfire3788 said:
    Has anyone tried turning off transparency while this is on I did and trust me it looks messed up...
    let me see if I can get a screen shot...
    wow my snipping tool wont work
    it just shows the X in the red circle and theres no Error message....
    I believe I have the same issue as you when you turn off transparency after enabling this tutorial.
    This is what I get.
    If transparency is on and you "show desktop".
    I do get these bars across the desktop.
  10. Posts : 71,960
       #69
    Hello Egydarceyes,
    Yeah, having transparency turned on is required for this to work when you enable the tutorial. If you turn off transparency, you will need to undo the tutorial to prevent the border background blending effect.
