Transparency - Enable Full Clear Glass Transparency
Page 15 of 15 FirstFirst ... 5131415
  1. Posts : 5
    Not good trick. Its only for windows explorer, not for all OS windows 7 ( taskbar and start menu)
    I dont like this tut by I lost my time and work for it.
    I only want clear blur for taskbar and start menu and windows explorer isnt important
  2. Posts : 72,061
       #141
    Hello Cambodia, and welcome to Seven Forums.
    Yes, that's what it says the tutorial is for at the top, and what the example screenshots show.
    This will show you how to have the window borders fully clear and transparent like glass instead for your current account only, or for all user accounts on the computer.
    For the Start Menu and Taskbar, see the tutorial below instead to check the "enable transparency" box.
    Transparency - Enable or Disable
    Hope this helps, :)
  3. Posts : 5
    Ok. I'll retry. Last try blur in my window became black side and previous tries it dont run.
    I edited Hide blur with DWORD as 1 ; ColorizationBlurBalance as 0, ColorizationOpaqueBlend as 1; ColorizationBlurBalance as 1 ; ColorizationColor as 1 ; ColorizationGlassReflectionIntensity =1.
    I hope too.
    Thank to hellp :)
  4. Posts : 72,061
       #143
  5. Posts : 5
    Sorry, but it dont work . Its bigest problem when I creat theme. I cant continue working and must stop it.
  6. Posts : 72,061
       #145
    Please elaborate on it didn't work, and what you mean by can't continue working.
    It looks like it worked as far as making everything transparent.
  7. Posts : 5
    Thanks for hellp. But the link error. I search this soft and feel it isnt good, it do blur and transparenty all.
    Theme with mistake blur , I cant fix it and cant finish too
    I stop to do it and waitting help from few 4rums.
  8. Posts : 72,061
       #147
    Here are some working links for wTrans from Brothersoft.
  9. Posts : 5
    I tried it and this soft only blur windows. All blur, taskbar, icons, menu, text,... and more dark
    When you install and you must boring by other soft install (hide so you know that but can choice) and set search conduil to FF, GC. You should not try it.
    I need trick or soft to clear blur, not blur for all T_T
    Anyway, thank for help, you very good
