Transparency - Enable Full Clear Glass Transparency
Page 9 of 15 FirstFirst ... 7891011 ... LastLast
  1. Posts : 29
    Windows 7 Professional (build 7600)
       #80
    No no no, sorry when I initially read LFB post, I thought he meant the bars will disappear from the "Peek Desktop" when I edit that registry key. I didn't know he was specifically talking about the window borders.
    Actually that worked just fine, still waiting on the "Peek Desktop" fix though.
    Also a side note Brink,
    This tutorial was perfect an easier way to do it is if you change "HideBlur" in the registry HKEY_CURRENT_USER\Software\Microsoft\Windows\HideBlur to '1' instead of '0' should also enable the full glass transparency.
  2. Posts : 71,977
       #81
    LOL, ok. No problem. :)
    HideBlur should be in the location below instead, but it is already included in the .reg downloads to set it to 1.
    HKEY_CURRENT_USER\Software\Microsoft\Windows\DWM
  3. Posts : 5
    Know someone this option is available on Windows 7 RTM ??? Because for me it is's working. Also i used that option with HibeBlur registry key but also that isn't working. i remember that i do that full transparency with a special programa but i don't remember the name ??? It isn't windows 7 tweaker i tried it.
  4. Posts : 71,977
       #83
    Hello Yoncy,
    Be sure to double check that you did every step, and try OPTION TWO for all user accounts. Also, restart the computer afterwards as well.
  5. Posts : 5
    Brink said:
    Hello Yoncy,
    I tried all the options available, seems not to work, also o serach the registry for that keys modified also them, also i tried the method with replacing the two dwm.exe and it's .dll asociated. I expect confirmation for someone that this works, and how he has done.
  6. Posts : 71,977
       #85
    Yoncy,
    It's confirmed to work as outlined in the tutorial. Please start over being careful to do and follow each step. Maybe you missed something, a mistake in one or missing one step will cause it to not work.
  7. Posts : 5
    I tried again and for me isn't working. I followed all the steps correctly (i'm not a novice in computers, i am programmer). My windows 7 is build 7600 x64 and for me that error that was remembered in the anterior posts (a .dll is missing dwmredir.dll appears). So i think for some SO that version of dwm (7127) isn't compatible and isn't working. I saw that for someone works but for me not so the solution isn't 100% sure.
    PS. i haven't Aero Preview on my 7600 you have this ? maybe isn't working for those who haven't Aero Preview.
  8. Posts : 71,977
       #87
    Yoncy,
    I have Aero Preview turned on, so that may be it. Test with it and Transparency turned on to see if that may help.
  9. Posts : 3
    Windows 7 RC (build 7100)
       #88
    what the hell
    Attached Thumbnails Attached Thumbnails Transparency - Enable Full Clear Glass Transparency-capture-01-18_11_10-.png
  10. Posts : 71,977
       #89
    Hello Longi, and welcome to Seven Forums.
    Did you extract the .reg file from the .zip file before trying to run (merge) it?
