Transparency - Enable Full Clear Glass Transparency
Page 11 of 15 FirstFirst ... 910111213 ... LastLast
  1. Posts : 72,051
       #100
    Hello James, and Merry Christmas to you as well. :)
    Unfortunately, only those older system files had this option in them. It just will not work with any newer versions that I know of.
    However, you might be able to use something like Resource Hacker to compare the old file version with the new one to see if there may be some noticeable difference that stands out that is responsible for enabling this.
  2. Posts : 178
    Windows 7 (x64)
       #101
    Thanks for getting back to me Brink, :)
    I just thought i would ask before i start getting my hand's dirty look's like i will be now
    I will post back if i spot anything of interest.
    Thanks.
  3. Posts : 72,051
       #102
    OK. Hopefully so. :)
  4. Posts : 178
    Windows 7 (x64)
       #103
    Hi again Brink, :)
    I had a look at the "uDWM.exe" and "DWM.dll" and I couldn't find any significant differences myself but I aint no expert I can verify that it aint the Version # RES file as I assigned ones from 7600 build to the 7127 build files and it still works so I guess its sort of using up to date files as now they do say the proper build string :) But they still arent up to date they are still 7127 so oh well.
    Maybe Im making to much of this LOL
    Ill just keep doing it the old fashion way I guess.
    You have yourself a Merry Christmas and a happy new year mate. :)
  5. Posts : 72,051
       #104
    No problem James. I like digging around for alternatives as well. Newer file versions are always best if they can be used.
    Have yourself a Merry Christmas and a happy new year as well. :)
  6. Posts : 2
    thanks a lot dude Succeeded. but can it be possible to make windows explorer background transparent
  7. Posts : 139
    Win7 x86
       #106
    I would clearly prefer to click a checkbox to enable clear transparency or even better a customisable transparency setting in the themes? - maybe Microsoft has it already in the to-do pipe?
  8. Posts : 72,051
       #107
    You're welcome Ifro4u.
    Unfortunately, you would usually need a 3rd party skinning program like Stardocks WindowBlinds for something like that instead.
  9. Posts : 24
    Windows 7 Ultimate 64bit
       #108
    Hey, something really weird happend.
    I got 2 users on my laptop, one called Tawa, and the other is Administrator, the default Windows Administrator user.
    I set my default user to login on windows startup to Tawa. I very rarely use Administrator.
    Anyways, I tried to set Full Transparency on Tawa, [I already postd in this thread few pages back] I had the same problem again. Usually, I press WinKey+L to logout so I could restart my laptop.
    Now, I logged into the Administrator account, and the full transparency was working
    I tried logging into Tawa, everything is black, I can only see the moue cursor.
    Any idea how to fix this?
    EDIT: Note that both user accounts are Administrators
  10. Posts : 72,051
       #109
    Tawa,
    As a test create a new administrator account to see if it works in it. Maybe it's just a issue in the Tawa account since it works in the other Administrator account.
