#100
Hello James, and Merry Christmas to you as well. :)
Unfortunately, only those older system files had this option in them. It just will not work with any newer versions that I know of.
However, you might be able to use something like Resource Hacker to compare the old file version with the new one to see if there may be some noticeable difference that stands out that is responsible for enabling this.
