Partition / Extended : Logical Drives
Page 4 of 12 FirstFirst ... 23456 ... LastLast
  1. Posts : 9
    Windows 7 Home Premium(SP-1) 64bit.
       #30
    Thanks a lot! :)
    It seems that Method-2 is the most suitable rather than getting rid of "System"
  2. whs
       #31
    What is the reason you want to get rid of one partition. If it is because of the 4 primaries, there is an easier way to solve the problem.
  3. Posts : 9
       #32
    Yes, this is because of 4 primaries. I wish to add more partitions.
    I would like to have a look at the easier way if it is different from Method-2 mentioned by Bare Foot Kid.
    Thanks anyway!
  4. whs
       #33
    The easiest is to make the C partition a logical partition. You can do that with the bootable CD of Partition Wizard - that is probably what you refer to in the tutorial of Ted (Bare Foot Kid). Just highlight C in PW, go to the Partition Tab > Modify and you will see,
  5. Posts : 9
       #34
    I have installed PW home edition. And as you said, in the Partition tab I find the option and can make C: logical!
    But I didn't APPLY yet! coz...just wondering if I can do it from here, why should I use PW bootable CD??!!
    If you show green signal, I will press APPLY button in PW
  6. whs
       #35
    Right, You need the bootable CD of PW (last entry on the webpage) because you cannot run it off your system whilst this is active. Burn the .iso to a CD and boot the CD.
  7. Posts : 9
       #36
    Probably I could not make you understand!
    I mean, I am getting the same options to make C: Logical, at the PW that I installed in my Laptop. And it seems that I can make C: logical from within Win 7, rather than using the PW bootable CD.
    But question is that if I use in the installed version, is it OK / same with that with the bootable CD?
    OR I must have to use bootable CD, although I have the same options available in the installed version of PW??
    Thanks for support! :)
  8. whs
       #37
    I would use the bootable CD - I think from within the running OS it will not work. But I have never tried that. You can try and then tell us whether it worked - I doubt it though.
  9. Posts : 9
       #38
    Yes!! It worked..though I took a risk!
    However, it actually didn't work from within Windows as Windows was preventing to perform action, I guess; was showing an message that it will be done once restarted. And finally change was done by PW during booting windows..
    I am now making drives!!
    Thanks a lottttttttt!!!
  10. whs
       #39
    You are welcome. So my hunch was correct - you cannot change the OS partition from within windows whilst this is running, right?
