SSD - Install and Transfer the Operating System
Page 20 of 89 FirstFirst ... 10181920212230 ... LastLast
  1. whs
       #190
    The only one that needs to be aligned is your Volume 1 (as per your cmd picture). The C partition is then automatically aligned. Do the following commands:
    Diskpart
    List disk
    Select disk 1
    List partition
    Now you should see a result like this.
    Partition ### Type Size Offset
    Partition 1 Primary 100MB 1024 KB
    The offset (in KBs) has to be divisible by 4. And 1024 can be divided by 4. E.g. 64 would also be OK
  2. Posts : 21,004
       #191
    Diskpart
    List disk
    Select disk 1
    List partition
    Thanks you very much Wolfgang now I understand - sorry mate I am as I said a bit on the simple side with this stuff - now clear as mud LOL!!
  3. Posts : 264
    Windows 7 Ultimate 64 bit SP1 x64
       #192
    whs said:
    1. Proper alignment is very important for the SSD - not only for performance (up to 300% degradation with misalignment) but also for wear and tear.
    So speed is degraded badly, but it should still run faster than an HDD whilst it lives,
    but life expectancy would be down to months instead of a decade or two.
    3. The reallocation of drive letters is normal because the running system gets the letter C:
    Yes, exactly what I expected myself.
    BUT the reason I stated this was to show that the old Windows was still visible to the new Windows,
    and when I first added Dual Boot of Windows 7 to my old XP Laptop I was warned on this forum against allowing Win 7 and XP to see one another's partitions because System Restore on one could trash the other,
    so I feared that allowing Win 7 on SSD to see Win 7 on HDD might be another "gotcha".
    4. It sounds like your partition on the SSD was smaller than the partition on the HDD from where the image was taken.
    No, the HDD had a 1 MB "Unallocated" gap at the beginning, then Partition Wizard shows :-
    100 MB First Physical sector 2048, last Sector 206847 :- *:System Reserved
    25.0 GB First Physical sector 206848, last Sector 52635647 :- O:Old_C_Samsung
    My SSD is now shown as 1 MB "Unallocated" gap at the beginning, then
    55.8 GB First Physical sector 206848, last Sector 117227519 :- C:C_OCZ_System
    N.B. I like my partition labels to remind me what drive letters are expected.
    I learnt a hard lesson on my Laptop when all 7 partitions vanished and the Partition Wizard Boot Disc was able to show me 30 start/stop boundaries of where partitions used to reside. The Boot disc did not know the partition letters but was able to show me the labels - which at the time were system defaults because I never saw the need. After an hour of trying to remember and guessing I was able to select what to resurrect and then the Boot Disc gave me back a working system.
    I now know how important labels can be.
    5. Drag & Drop is the right way. If you drop into a partition on the SSD, the SSD will be automatically aligned by 1MB. If you drop into an unallocated space, the alignment will be as it was in the partition from where the image originated.
    6. I would not use the 100MB system partition. Move the bootmgr to C:, then you can ignore the 100MB partition. Bootmgr - Move to C:\ with EasyBCD
    Thanks - I should have done more preliminary research.
    I will know better the next time, but I will stick with what I have for now
    Regards
    Alan
    P.S.
    Using Macrium under Windows (running in SSD) when I select the 100 MB partition of the last HDD image, and drag/drop down onto the original 100 MB in the HDD,
    I can then click on "Restored Partition Properties" and this shows the alignment will be
    "Vista/t/SSD (1MB)"
    I get the same assuring message that all is well when I select the latest SSD image and drag/drop onto its existing 100 MB in the SSD.
  4. Posts : 21,004
       #193
    Thanks whs I ran what you said and got the right result - I think as there are three partitions sowing in this DISKPART and in Computer admin there appears only two but if the all important one is that first one then I must be ok?
    Attached Thumbnails Attached Thumbnails SSD - Install and Transfer the Operating System-diskpart4.png
  5. whs
       #194
    You are OK. Remember, the number divisible by 4 is at the KB scale. The offset of the other 2 partitions is in MB and GB. If you break that down into KB, then it is always divisible by 4.
    Example: the 101MB of your second partition become 101.000KB - and that can be divided by 4.
  6. Posts : 21,004
       #195
    Thanks so much Wolfgang I have just read the tut and should have done in the first place - impetuosity for you!
  7. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #196
    Kids! Always in a hurry!
  8. Posts : 21,004
       #197
    Yep sorry Dad - only don't just hit me again
  9. Posts : 3
    Paragon Migration worked like a charm
    Although I was very tempted to take the time and try the 'geeky' way just to learn something and have some fun, I realized in the end my time was more valuable and went with Paragon's Migrate OS to SSD. Worked like a charm. Took all of 10 minutes from download to finished transfer.
    But I learned a lot just thinking through the process and following the intial steps of Option 1 so thanks WHS for the excellent tutorial and follow up assistance.
    Cheers
  10. whs
       #199
    You are very welcome. Glad you could get the job done.
