SSD - Install and Transfer the Operating System
Page 23 of 89 FirstFirst ... 13212223242533 ... LastLast
  1. mjf
    Windows 7x64 Home Premium SP1
       #220
    I would not exclude
    Program files
    Program files (x86)
    exclude data files by all means
    You can disable hibernation and reduce the page file size. This will save you a lot of space. Tips here.
    I had an issue with the Paragon utility but what you are attempting should work fine I would have thought.
  2. Posts : 21,004
       #221
    Excuse me for butting in but whs that Gparted isn't or can't the same thing done with diskpart?
    Sorry mate but am a little confused as to the difference.
  3. whs
       #222
    I assume you mean diskpart clean or clean all. But that is not at all the same thing. E.g Clean All would write a bunch of zeros on your SSD (Clean without the All just resets the control records). What you want though is nothing at all on your Nands. And that is what you do with a Secure Erase - makes write operations twice as fast as if there were stuff on the Nand. Over time, garbage collection will do the cleaning too. That is why you always should leave some freespace on the SSD and let it idle at times.
  4. Posts : 21,004
       #223
    Thanks Wolfgang got that and yep that is what Gary said to do and I do leave it at idle for a couple of hours sometimes.
    Am sticking an SSD into the laptop that was why I was interested in what you had put. New one comes with that 0309 firmware now too which is a bonus eh?
  5. whs
       #224
    John, The latest FW is 000F :: Crucial m4 SSD FW update 000F
  6. mjf
       #225
    I upgraded from Fw 0309 to 000F. Unless you have an issue specifically mention in their update spec sheet I wouldn't make the move yet as I noticed a performance degradation. Their is no firmware rollback option.
    Crucial SSD support outside of North America in my opinion is about the worst I've come across.
  7. Posts : 21,004
       #226
    Blimey what on earth is going on at Crucial! Maybe I should have gone the Intel or even shelled for the Samsung.
    Hum just been back through a few of the posts and threads on this and don't know what to do now upgrade or not? Might even consider getting a Corsair or Intel and keep the Crucial as spare until it has been sorted out - pretty annoying though!
  8. whs
       #227
    I think you are right Michael. Not worth upgrading to 000F. The things they fixed in it will most likely not touch the average user.
    If I were you, I would write a letter to the CEO of Crucial. I have done that once with Sony and got immediate action.
  9. mjf
       #228
    Thanks for the comments Wolfgang. If a Company doesn't have a monopoly or a unique product, I think poor support will be its downfall.
  10. Posts : 21,004
       #229
    So stay with 0309 Wolfgang?
    As for Crucial and Michael having to go to that length is pretty weak in my mind.
    Really does make you wonder if it's worth staying with that brand.
