#350
This is pretty mysterious. I have never seen such a sequence of events. You should have never gotten the "Preparing your desktop' to start with since you imaged a running system - at least I assume that the system was still running from the 40GB SSD after you copied the bootmgr. I suggest to test that too with all other disks disconnected.
If that works, then you must have made a little mistake during the imaging and we can take it from there.
