SSD - Install and Transfer the Operating System
Page 43 of 89 FirstFirst ... 33414243444553 ... LastLast
  1. mjf
    Windows 7x64 Home Premium SP1
       #420
    As WHS says it is up to you. I have system reserved on 2 PCs and no system reserved on a 3rd. It doesn't matter and my decision was quite whimsical since I don't use bitlocker.
    Before you assume "MS know best" the system reserved at 100MB was not a good choice. Mine are 200MB for good reason. If you use Windows inbuilt imaging and a 100MB system reserved some users have run into trouble (shadow storage copy issues)
    Backup Error 0x81000019 - Fix
  2. Posts : 16
    Windows 7 Pro x64
       #421
    Britton30 said:
    I don't use the Reserved Partition and have no trouble. As for MS having a good reason, they are the people who brought us Windows ME, IE7, and Win 8.
    Macrium has the option to verify an image too, bit by bit. Better than the XPired ideas with DOS.
    Ok, I have decided to go with Macrium.
    Can you guide me on how to proceed?
  3. whs
       #422
    Start with this tutorial: Imaging with free Macrium
    If you have questions, let us know.
  4. Posts : 1,568
    Windows 8.1.1 64bit
       #423
    Used Paragon Migrate OS to SSD;
    How do I turn off Hibernate ?
    The Win7 is still on the HDD, should I just wipe it ?
    Any advice ?
  5. whs
       #424
    Any advice ?
    The command to get rid of the hibernation file is powercfg -h off
    If the SSD system works well, you can get rid of the OS on the HDD - just reformat the partition and also the 100MB system partition (if any). But make first sure that the SSD does not depend on it. Post a screenshot of your Disk Management. Use the space to make images from the SSD.
  6. Posts : 1,568
    Windows 8.1.1 64bit
       #425
    WHS, thank's for the quick reply.
    Where do I use the command ?
    I don't see how the SSD is dependant on it as the HHD is disconnected now.
    I use a external HDD for back-ups if this is what you are reffering to.
  7. whs
       #426
    The SSD looks OK. No need for the system on the HDD any more
    The command is for Command Prompt. Go to Start > All Programs > Accessories > right click on Command Prompt > Run as Admin. Then you get a small black window where you can enter the powercfg command. Then press Enter.
  8. Posts : 1,568
    Windows 8.1.1 64bit
       #427
    WHS, command did its job.
    I can do a quick format on the HDD ?
    Is there any part of the OS I should transfer to the HDD ?
    Maybe not the OS itself but some user folders ?
  9. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #428
    quick format will work. Saving some user data will be a start as a backup.
  10. whs
       #429
    I always keep my user folders on the HDDs. Do the following:
    1. On the HDD, define folders for Documents, Music, Videos, Music
    2. Right click on those folders and INCLUDE them into the approriate library
    3. Copy your own folders (not the main folders like My Documents) to these folders on the HDD
    4. Done - in the future, move your stuff always into the HDD folders
    5. The main folders on the SSD will be used by some programs (especially the Documents folder). That's why they have to stay there. But the amount of data that those programs put into there is minimal.
    PS, keep all OS files on the SSD. And as Gary says, always use quick format.
