SSD - Install and Transfer the Operating System
Page 47 of 89 FirstFirst ... 37454647484957 ... LastLast
  1. whs
       #460
    Looks like you are ready to go. Welcome to the club.
  2. Posts : 1,568
    Windows 8.1.1 64bit
       #461
    Thank you kind Sir.
    I must add, Paragon Migrate made the transition very easy.
    Well worth the $10. spent.
  3. whs
       #462
    COMPUTIAC said:
    Thank you kind Sir.
    Although I have the Paragon program, I usually do the migration the manual way. That's more fun. But I have done that a dozen times. For a one time migration, the Paragon tool is the best option.
  4. Posts : 1,568
    Windows 8.1.1 64bit
       #463
    The new SSD is running fine so far.
    Do have a couple of questions though:
    How do I send something to the HDD ? When I right click on something, "send to" is there but, not the (D) HDD. I have not put any folders on it as yet.
    How do I have Acronis 2012 include it on the Back-ups ?
    If I open Acronis > add new disk > this opens:
    If I cancel it, then open properties, it shows:
    Should I let it delete the MBR on it ?
    Lastly, I ran ATTO for the first time, not sure how to interpret the results:
    (Sorry if I posted any of this in the wrong place.)
  5. whs
       #464
    If you want to move or copy something to D, I would use this: Context Menu - Add Copy To Folder and Move To Folder
    If you want to use Sendto, you have to add a shortcut of D to the Sendto folder.
    No idea on Acronis. Have not used it in years. But better not delete the MBR.
    The Atto data is average. But those nums vary a lot from HDD to HDD. Here is an example of my Crucial M4 on this system.
    Attached Thumbnails Attached Thumbnails SSD - Install and Transfer the Operating System-2012-01-19_1122.png
  6. Posts : 1,568
    Windows 8.1.1 64bit
       #465
    WHS, thank's for the quick reply.
    How do I add D to the send to folder ?
    Where do I find it ?
  7. whs
       #466
    I thought you were going to ask that, LOL. Here is how:
    1. make a shortcut of D on the desktop (highlight in Computer, right click, create shortcut)
    2. type shell:sendto into start/search, hit Enter
    3. drag the shortcut into that folder
    4. close the folder, DONE.
  8. Posts : 1,568
    Windows 8.1.1 64bit
       #467
    WHS, of course you did.
    Anyway I did a search of the tutorials and found this:
    Google Drive - Add to "Send To" Context Menu
    Which made things easier.
    So tell me, what else am I going to ask you ?
    Thank you !
  9. whs
       #468
    Golden is a good man. But I think my method was a easier to follow. LOL
    Your next question is going to be pertaining to your Atto nums ==> why are they not higher, especially the 4k nums ??
  10. EM2
    Windows 7 Pro x64
       #469
    Not sure what I'm missing here but I can't boot from my ssd.
    I used the paragon program to migrate the os, skipping the user and documents and settings folders. I also enabled AHCI in the bios and also enabled it in the registry.
    The ssd is set to boot first, but when I unplug my hdd it won't boot. Is it because it's not named C?
    http://i95.photobucket.com/albums/l1...ps2b6ee754.jpg
