SSD - Install and Transfer the Operating System
Page 58 of 89 FirstFirst ... 48565758596068 ... LastLast
  1. Posts : 125
    windows 7 home premium 64bit
       #570
    so on macrium, you backup the hdd with bundled windows, and then you format it to becomes blank and use it.
    have you ever try restoring the bundled windows image to the now-formatted hdd? does it work?
    is it as simple as clicking backup, saving the backup, and restoring said backup to macrium reflect? (for the original hdd)
  2. whs
       #571
    Now you are throwing up a few questions.
    1. The new laptop with or without Windows. If you want my opinion, I would buy without Windows 8 and buy a Windows 7 for appr. $80 tp put on the SSD. Newegg was offering Windows 7 for $80. Alternatively, I would put Linux Mint Mate on it. A really nice OS that is for free. I have all the setup tutorials for it if you need them.
    2. If you buy with Windows 8, then I think the best method is to use the unused space on the HDD for storage in the caddy. I do that all the time. Usually most of the space on those preinstalled HDDs is free. But it would require to have a look at Disk Management to see whether it is UEFI or MBR and the number of partitions already on it.
    3. And yse, Macrium could image your whole HDD. But as I said, I would not go that route.
  3. Posts : 125
       #572
    i hv the windows 7 FPP. thats what i was using on my old laptop... but yeah these laptops they sell in south east asia they dont provide win7 driver more often than not. whether its a cd or web download. only windows 8. thats why i hv to budget the win8 software as well :9
    i prefer win7 myself, no metro ui. it feels jarring against the desktop.
  4. Posts : 477
    Windows 7 Pro 64bit SP1
       #573
    Thanks much...!!!...I've read thru this but not sure about the following...Old Drive has 2 partitions...Windows 7 installation on 1st (primary-active-boot-system) partition of about 205GB - but only using about 80GB for the whole installation (130 or so GB's are free/unused on 1st partition)...and second (logical)... partition of about 250GB mostly empty and used only for storage...no programs, etc...on this second partition
    My new Samsung SSD has 128 GB capacity....been using ATIH since version 2011. If use ATHI2013 to move my system (Windows instantiation and programs/files etc) from the current Windows 210GB partition on the HDD (205GB) to the new SSD (128GB) ??
    I have multiple C: drive backups (full tibs of C: partition only - partition size 205GB out of 500GB)
    Does the SSD's total GB have to be greater then the 1) C: tib file, 2) entire current C: drive...etc ??
    Is there an issue with moving/copying/restoring from Acronis tib (on external USB drive) a 209 Partition from USB external backup drive to the Samsung 128GB SSD drive ? Actual use of Win 7 Pro 64bit partition on HDD is only 72GB of 205GB now ?
    Thanks...TR
    Attached Thumbnails Attached Thumbnails SSD - Install and Transfer the Operating System-current-box-setup.jpg
  5. whs
       #574
    The data on C has to fit on the SSD. The total size of the C partition is irrelevant. Looks like you have to get rid of a lot of stuff from C in order to fit. Two generic things you can do to reduce the size:
    1. reduce the pagefile to 2GB
    2. get rid of the hiberfile. The command is powercfg -h off
    For the rest you have to see. What is all this stuff. A normal Windows 7 with a good set of installed programs (no games) should be less than 25GB.
  6. Posts : 330
    Microsoft Windows 7 Professional 64-bit SP1
       #575
    If I were to order a laptop and decide to swap the HDD for an SDD, but plan on installing a fresh install (never installed before) of 7 on the new ssd, would I just go about setting up the SSD as usual?
  7. whs
       #576
    Right, installing on a SSD is no different than installing on a HDD. There are a couple of things that the installer does for you which are essential for the SSD - it aligns the SSD and shuts off defrag. So once the OS is installed , there is nothing else for you to do.
  8. Posts : 330
       #577
    Excellent. I'm thinking of a samsung 250gb, do you recommend setting up a partition for the OS? I was trying to figure out this out the last time I did a reinstall but couldn't decide on the size needed.
  9. mjf
    Windows 7x64 Home Premium SP1
       #578
    Here is a snapshot of my OS partition.
    No way I could get it down to 25GB and there are no games. The Winsxs is 11GB and I don't think there is anything I can do about that. Winsxs appears to be a bit of a garbage tip but you don't know the difference between the garbage and the good stuff. It looks like an MS Windows architecture weakness to me. I run regular disk cleanups.
  10. Posts : 16,163
    7 X64
       #579
    Don't know how you managed that. Mine is 7.7gb
      My Computers
