SSD - Install and Transfer the Operating System
Page 59 of 89 FirstFirst ... 49575859606169 ... LastLast
  1. Posts : 330
    Microsoft Windows 7 Professional 64-bit SP1
       #580
    So you answered my first scenario in the other tutorial, now heres my other situation. I'm looking at a refurbihsed laptop with all the bells and whistles I'd like to have, except the SSD. Is this tutorial essential for swapping the HDD for the SSD if I use an ISO on a jump drive then use the OEM that came with the laptop, or is that activation locked to that particular HDD
    Esentially swapping the HDD for the SDD, but use the ISO to just fresh install on the SDD
  2. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #581
    It's the key which determines the version, not the ISO. I assume the ISO is not one created from an existing install.
  3. Posts : 16,163
    7 X64
       #582
    You will be fine to use a different hd or ssd. There is a points system, usually only triggered by change of motherboard.
      My Computers
  4. Posts : 330
       #583
    No I figured on using the http://www.heidoc.net/ isos as the refurbish does not come with a disc (I believe it does not)
  5. Posts : 24,479
       #584
    That will be fine. Once activated with the OEM key it will be locked to that machine.
  6. whs
       #585
    bberkey1 said:
    whs said:
    bberkey1 said:
    If I were to order a laptop and decide to swap the HDD for an SDD, but plan on installing a fresh install (never installed before) of 7 on the new ssd, would I just go about setting up the SSD as usual?
    Right, installing on a SSD is no different than installing on a HDD. There are a couple of things that the installer does for you which are essential for the SSD - it aligns the SSD and shuts off defrag. So once the OS is installed , there is nothing else for you to do.
    Excellent. I'm thinking of a samsung 250gb, do you recommend setting up a partition for the OS? I was trying to figure out this out the last time I did a reinstall but couldn't decide on the size needed.
    The Samsung is a good SSD. But have a look at this one. This is also an excellent SSD for an unbeatable price - at least today.
    If you predefine an aligned, active, primary partition on the SSD and install into that, then you do not get the 100MB system partition - which is good in my book. 50GB should be ample for the OS unless you need to install BIG games.
  7. Posts : 330
       #586
    Right thats what I figured, but if the laptop comes with 7 pro already installed, the OEM already be locked to that computer, but the change of hard drives should be no concern as per SIWs remarks correct?
  8. whs
       #587
    Changing the disk is really no big deal - if you make no mistake, LOL.
  9. Posts : 330
       #588
    thats why I cling to the forums
    Thanks for the link gives me another option in my quest.
  10. Posts : 24,479
       #589
    That's correct.
