#610
Ok, I'll admit math has never been my strong suit (it whipped my ample asset quite thoroughly once I hit college, enough so I had to change majors) so I very well may be applying the divisible by 4 thing wrong (along with many others who I've seen posting the same thing). Using the program I linked, however, makes the issue moot.
Nice to know a fresh/ clean install on a new ssd doesn't need allot of this technical stuff done :)
The optimizing stuff though has that changed with new ssd's
The optimize tutorial is close to 5 years old :/
Cheers.
I know what you mean Wolfgang and I am no great mathematician to me it is simple binary stuff.
Issue
No monitor to see what's going on
Got the ssd on external now but wants to initialize the disk and I'm not sure which option to use
desktop spec's are correct I'm accessing it via my laptop Help please
Attachment 337517
This one popped up as soon as I opened disk management now sure what to do with it ?
Attachment 337518
I usually use diskpart and set the offset (alignment) at 1024 which is what the installer will set it as if you were doing a clean install. I believe disk management will do it the same. I've only done 1 in disk management and it aligned it at 1024.
If you want to do it in diskpart, I can give you the commands.
Hi Steve
I do indeed need help :)
Wolfgang has the commands but I was under the impression on a clean install the install would do all of that ?
Issue seem more the missing monitor booting to it when the ssd is inside the desktop tower :/
The laptop is a 32 bit system and the desktop is a 64 bit system ?
I'm an idiot so please be gentile lol
I'm sure you know spelling and syntax are important. If you are doing a clean install, the installer will do it for you and if you format the drive first, you will not get the 100MB partition.
1. diskpart press enter wait and the command prompt will reply diskpart
2. list disk press enter and the cmd will show all disks and assign each a number. Choose the number of your SSD You will be able to tell by the size. assume it is disk #1
3. select disk 1 press enter it will reply disk 1 is the selected disk
4. clean press enter, not necessary with a new disk, but I do it anyway, it will reply diskpart succeeeded in cleaning the selected disk
5. create partition primary align=1024 press enter will reply created the specified partition.
6. select partition 1 press enter reply- partition 1 is the selected partition
7. format fs=ntfs quick press enter reply will be formated the selected partition
8. active press enter reply - the partition was set to active
9. exit press enter will take you back to where you started
10 exit press enter will close the command prompt
If you are not going to use it as an Operating System Drive, do not set it active
If you are going to use Paragon Migrate you don't have to do anything. Paragon will do everything for you. You have to be sure the OS you are transfering is smaller than the space on the SSD.
It will look similar to this, I did this as an example
