SSD - Install and Transfer the Operating System
Page 65 of 89 FirstFirst ... 55636465666775 ... LastLast
  1. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #640
    Should I redo diskpart ?
  2. Posts : 20,583
       #641
    I believe the ssd defaults kicked in ?
  3. Posts : 26,871
    Windows 11 Pro
       #642
    Mike, just to see, I did the same commands on one of my SSDs. I copied and pasted the commands I wrote for you, this is what it looked like except I was using a different disk number. This is what I got
    This is disk management when I finished. It's the last disk.
  4. Posts : 26,871
    Windows 11 Pro
       #643
    Before you get any farther in the install, I would do what Greg suggested and use Partition Wizard and give it a try.
  5. Posts : 20,583
       #644
    This ssd was supposed to be 256gig
    It obviously has some stuff on it or something to not show the correct amount ?
    SSD Suggestions
    Yep I was thinking of that Greg's suggestion
  6. Posts : 26,871
    Windows 11 Pro
       #645
    When you typed clean, it should have deleted all partitions on the drive.
  7. Posts : 20,583
       #646
    Doing the Magic now :/
  8. Posts : 20,583
       #647
    Well I'll say it again that's one quick freaking tool
    Attachment 337553
    That's one big System Reserved partition too!
  10. Posts : 20,583
       #649
    I went as far as I could without doing it again ?
    It only offered so much :/
