#800
Thanks for the great tutorial. I'm about to try it out. My system is Win 7 Home Premium SP1 32 bit with 300 GB HDD divided into four partitions C:, D:, E:, F:. Just recently I bought two new drives: one is Samsung SSD 850 PRO - 128 GB, another is HDD 1 TB.
What I want is to clone my C: drive (58.13 GB) to SSD (119.24 GB), and to continue to use my old and new HDD drives. When the new Windows 10 arrives, I want it to be installed on SSD as well.
I have already initialize my new drives in Disk Management window.
My first question - what should I do with partition called WinXP (14.0 GB) on my old drive (see the attached capture)? As far as I can recall, it's a redundant partition that was created long ago by Acronis Backup & Recovery (as a hidden partition) and never used since I uninstall the application. Some time ago I shrunk it from ~50 GB to the current size of 14 GB with 7.89 GB free space. Is it possible to see the content of this WinXP partition ? Can I just delete it?
I have already applied the AHCI in windows registry, but not in BIOS yet. I'll set the BIOS to AHCI prior to activating SSD. My second question - does it matter that in my registry HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services
the value msahci was initially set to 0 (zero). Actually, I only changed the iaStorV from 3 to 0.
