WIM File - Extract and Modify
  1. Posts : 1
    widnows 7
       #20
    This is what I did wim file - Extract and Modify after this is finished How do you create a wim file after it's been modified and put it back to wim file for it to work
  2. Posts : 2
    Modified install.wim
    Hi, thanx for the tutorial. I followed the steps successfully but wanted to know where the modified install.wim is? Will it be placed back on the c drive?
  3. Posts : 1
    windows 7 ultimate x64
       #22
    Thanks.
    It worked for me.I edited boot.wim and install.wim & made changes.when i will install it i will be having everything i added.
  4. Posts : 2
    windows 7 ultimate x32
       #23
    imagex is not recognized as internal or external command
    hey ,
    i do all those things which u tell to do ! then i open the command ... i enter those code and the result was ' imagex' is not recognized as an internal or external command, operable program or batch file......
    although i download only the ' imagex.exe 'file from the google!!
  5. Posts : 72,052
       #24
    Hello Sumit, and welcome to Seven Forums.
    You will need to download WAIK first to get the ImageX.exe file, and then copy the ImageX.exe file to your C: drive. The red warning box at the top of the tutorial will have the download link. :)
  6. Posts : 2
       #25
    editing the .wim file
    hy author,
    i thought i should edit the ' install.wim' file in my own way. i do the following steps:-
    1) extract the content of install.wim file by using "winmount"
    2)then add the 'MICROSOFT OFFICE ' to program file in filder named '1'
    3) and then convert it again to wim file format by using "gimagex".
    4)i replace the old install.wim file in windows 7 cd in sources folder with this new one..
    5) burn it to dvd
    6) boots but when i click on install it shows the message '
    Windows could not display the images available for installation.'
    pls help me how to install windows 7 which have preinstalled microsfot office
  7. Posts : 51
    Windows 7 Ultimate 32bit
       #26
    Not able to Modify Files
    Hello i m not able to make changes to mounted files of wim
    It says this :
    Please Help me.
  8. Posts : 72,052
       #27
    Hello Ankur,
    It looks like you will need to use OPTION THREE in the tutorial below to take ownership and "Allow" your user account "Full Control" of the file first.
    Take Ownership of file - Vista Forums
  9. Posts : 5
    hi,nice working tut. but how that commit works? my wim file is getting bigger even if i delete files... I deleted about 250MB from .wim and file is bigger about +2MB(at start 1000MB, after delete 1002MB).
  10. Posts : 16,161
    7 X64
       #29
    It doesn't pack tightly using commit.
    It will keep getting bigger.
    Suggest you use Export and select max compression.
    You can't export with win7 dism - use command imagex, or much easier to use Gimagex
    GImageX - AutoItScript
      My Computers
