Internet Explorer 9 - Enable or Disable Ability to Pin Sites
Page 2 of 2 FirstFirst 12
  1. Posts : 72,084
    Hello NoN,
    Yeah, On or Enabled is the default setting for this.
    It may be a cookie issue, or some issue with that site. I just pinned this page to the Start Menu and opened different new windows to the site as a test, and I was still logged in. Does it do this with other sites as well?
  2. NoN
    Brink said:
    Hello NoN,
    It may a cookie issue, or some issue with that site. I just pinned this page to the Start Menu and opened different new windows to the site as a test, and I was still logged in. Does it do this with other sites as well?
    Hi there, thanks for your respond...
    I still got that issue with sevenforums as today. I'll check later with another site when i'll logged in.
    PS: I actually use IE9 x32bits. When i open a new IE9 x64bits windows or x32bits it is still the same, not logged-in in the separate open window.
  3. Posts : 72,084
       #12
    NoN,
    See if deleting the cookies using the link below and logging in again may be able to sort it.
    vBulletin > My Cookies
  4. NoN
    Brink said:
    NoN,
    I'll try that...
    It does not do it when i open a new tab...only in a separate window!
    EDIT:
    When i do click in a tutorial link as exemple, it does open a new window and i'm still logged in.
    But when i do open a separate IE9 blank page and go in "Favorites" openning a SevenForums link, i'm not logged in!
  5. Posts : 72,084
       #14
    NoN,
    Did deleting the cookies help stop this?
  6. NoN
       #15
    Brink said:
    NoN,
    Well, i can't really tell as i did it through your link and explained post above the behavior in the "edit:"
    It does the same in another site when i'm logged in.
    So, to clear my situation:
    1) I open a window for a site and i'm logged in, I do open New Tab (same site) i'm still logged on...
    2) I'm logged-in in the same site, i click a link inside the same web site, then a new separate window open, i'm still logged on.
    3) I'm logged-in in a site (SevenForums for exemple) but if i do open a separate window (blank page) then go in Favorites openning the same site, i'm not logged on.
    It's no big matter, i'm only curious if it's a normal behavior!!
    Thanks!
  7. Posts : 72,084
       #16
    NoN,
    No that's not normal. It still has me logged in with your #3 example. You might see if resetting IE9 may help.
  8. NoN
       #17
    Brink said:
    NoN,
    Hey thanks for this...
    i'll try to reset all my internet options! :)
    It's no big deal but wanted to be sure.
    I was thinking afterward it was made for security purposes, but looks like not!
  9. NoN
       #18
    Hi Shawn,
    Reseted all internet options and deleted my personal settings for IE9, rebooted the machine but it is still the same....
    I'll let it be for a while. Thanks again for your time!:)
  10. Posts : 72,084
       #19
    NoN said:
    Hi Shawn,
    Strange. Stubborn one.
