Screen Saver Password Protection -Enable or Disable
Page 2 of 2 FirstFirst 12
  1. Posts : 8,476
    Windows® 8 Pro (64-bit)
    Thank you Shawn. :)
  2. Posts : 72,037
    You're welcome Dinesh. :)
  3. Posts : 11
    Windows 7 Pro
       #12
    That surely should fix the log on screen issue. I followed the procedure your posted with no problem. Thanks!
  4. Posts : 8,476
    You're welcome.
  5. Posts : 13
    Is there a similar setting to require a pasword when the display is turned off in power settings?
  6. Posts : 72,037
       #15
    Hello Deejay,
    Not that I'm aware of, but you could use the tutorial below as a workaround to be able to lock the computer and turn off the display at will from the desktop context menu. Since the computer is locked, it will require a password when you wake/turn on the monitors.
    How to Add "Lock Computer and Turn Off Monitor" to the Context Menu in Windows
  7. Posts : 207
    Windows XP Professional SP3/Windows 7 Ultimate x64
       #16
    hi Brink, I followed your steps but I have the following issues:
    1) the "Change screen saver" link is not present in the left pane of Control Panel/Display
    2) I was able to check the "On resume display logon screen" checkbox under "Screen Saver Settings"
    3) A "Merge" option is not present in the display menu when right clicking the reg file in the Desktop
    My user account is set to Administrator with full privileges and I set a log on screen password in my User Account. However the screensavers do not prompt for a password when resuming, even when the step 2 above was successful.
    Any suggestion? Thanks
    UPDATE: I was able to open the reg file using "Open with.." and selecting "Registry Editor" and it was merged, however the "Merge" option is not present as stated before. I rebooted and now the screensaver is password protected upon resume as desired, however the option to "On resume display logon screen" is grayed out.
