Windows 7: SFC /SCANNOW Command - System File Checker
28 Jan 2013   #420
lehnerus2000
W7 Ultimate SP1, LM18.1 MATE, W10IP VM, W10 Home, #All 64 bit
Preferred Option
I'm going to recommend a clean reinstall (as my preferred option).
He has a lot of random stuff on his laptop.
I'd be surprised if he still uses all of it (he tends to install programs and then only use them once or twice).
It doesn't take that long to reinstall Windows and programs (and he has an SSD).
He just started 2 months Long Service Leave (that should be ample time).
If he doesn't want to do that, then I'll follow the "view the CBS log and replace the corrupt files" option.
29 Jan 2013   #421
Brink
64-bit Windows 10 Pro
Agreed. Clean installs always (well usually) give good results.
02 Feb 2013   #422
Wexprestart
Windows 7 home basic 32bit
Can somebody please help me. I tried sfc/SCANNOW and a massage saying 'you have to be an administrator running a console session in order to use the sfc utility'. I hve only one user account in this laptop and it is an administrator account. Please help me with this problem
02 Feb 2013   #423
Golden
Microsoft MVP
Windows 7 Ult. x64
You need to do this:
Elevated Command Prompt
1. Click Start
2. In the search box, type cmd
3. In the list that appears, right-click on cmd.exe and choose Run as administrator
4. In the command window that opens, type sfc /scannow and hit enter.
Regards,
Golden
19 Feb 2013   #424
djbillyd
Windows 7 Ultimate 64-bit
sfc/scannow
Brink, when I first posted on this thread, it was because ny "Windows Explorer" was running too slow to be bearable. I assumed that through all of the comments and tests and scans, that I would be working OK. Well, PHOOEY to that! Is there anything we may have missed trying to find a solution to this problem? It stopped for a long time, but started again last night. This is the system that I do EVERYTHING on, so you can imagine how frustrating it is to have the primary system tool screw up like that.
Any new suggestions as to why Explorer even does that?
19 Feb 2013   #425
Brink
Hello Billy,
Sorry to hear that it's acting up on you again.
You might see if doing a system restore using a restore point dated before this started again may be able to undo what caused it and fix it.
20 Feb 2013   #426
djbillyd
sfc/scannow
Yeah, I did a "Startup Repair", which said it couldn't fix the problem, and sent a report, and it has worked since. I don't know what this is...
20 Feb 2013   #427
Brink
Glad to hear it has worked since.
27 Feb 2013   #428
catch22
Win7 Professional x64
Quick question about SFC.. How do I read the logs?
is a
  0000032f [SR] Beginning Verify and Repair transaction
 Repair results created:
an indication that something has been fixed or is that general output? after that snippet, there was some "move file" commands taking place..
27 Feb 2013   #429
Brink
Hello catch22,
If you like, use OPTION THREE to create a sfcdetails.txt file, and upload it. I'll be happy to take a look at it, and post with some explanations to help read it.
system file checker log does not show file not repaired
Ran system file checker and it said it found corrupted files but could not repair all of them. Looking at the log is not helping. I have posted the last several lines as they are representative of the entire log with the exception of the last few lines that mention an actual repair. Where is the...
Performance & Maintenance
System file checker
Does anyone have a link where I can find a list of all the commands ( and what they do) for System file checker in Windows 7 ? thank you Joe
SYstem File Checker Result - CBS.Log file says Access Denied
I have just completed a System File Check and some repairs were done I was told that the relevant report could be seen at C:\WINDOWS\LOGS\CBS\CBS.LOG. When I Clicked on that I got Access Denied How can I Open that log file? I am the Administrator
system file checker
long story short l have a external drive which keeps on telling me to scan it, l havent the space to backup the content on it and reformat etc and whenever l use the file system scanning tools it seems to stop at a specific record at which point l have to disconnect and reconnect the drive again to...
New System File Checker : sfc /scannow tutorial
I hope this will be a help to some and I would appreciate any feed-back. :) SFC /SCANNOW : Run in Command Prompt at Boot Edit: I've just added a Method Two to this. :)
Chillout Room
System File Checker
I am trying to use system file checker tool (sfc.exe) and I am running win7 ult 64bit. I am CERTAIN that I have corrupted files in windows. When I try to use any of the programs like Windows Experience, Generate a system health report, or look at files in Event Log(event log is unable to give me...
BSOD Help and Support
