Page 11 of 99 FirstFirst ... 91011121321 ... LastLast
  1. GWT
    Windows 7 Professional x64
       #100
    Back in the XP days, I used to do the same thing and inevitably I'd have to take out the XP disk and do repairs from the CD drive. I've never had to do that here in Win7, which is strange since after a few months, something should inevitably get broken.
    This text file really doesn't tell me much of anything.
  2. Posts : 72,046
       #101
    GWT,
    If you like, you could upload and attach the TXT file, and I'd be happy to take a look at it and let you know what it means. :)
  3. GWT
       #102
    Allright. Txt file, attached...
    SFC /SCANNOW Command - System File Checker Attached Files
  4. Posts : 72,046
       #103
    Congratulations GWT. The log file shows that SFC did not find any system file errors or corruption. :)
  5. GWT
       #104
    That's surprising since in XP, things broke all the time.
  6. Posts : 72,046
       #105
    LOL, give it time. Any modified system file would be included as needing to be fixed by SFC as well.
  7. Posts : 2
    windows 7 64bit
       #106
    heya
    I'm having an issue with my mpr.dll file which is shown to be corrupted through my cbs.log any pointers as to how i should fix this? I havent been able to install anything new because of it and its getting old fast. Any help would be appreciated =] i've ran sfc /scannow 3 times and it couldnt fix the issue ill try to look into the dvd file extraction fix
  8. Posts : 72,046
       #107
    Hello Phantomcide, and welcome to Seven Forums.
    According to your log file you also have a corrupted MPG4DECD.DLL in addition to the mpr.dll file. I have a clean copy of the files from my system in a ZIP file below for eash folder location below. After extracting the files (be sure to only do all of this for one ZIP folder at a time) do step 12 and the yellow TIP box under it in the tutorial below to replace your corrupted copies with the attached ones in each folder location below one at a time.
    Extract Files from Windows 7 Installation DVD
    • C:\Windows\SysWOW64
    • C:\Windows\System32
  9. Posts : 2
    windows 7 64bit
       #108
    Wow got it to work thanks a million brink your the best btw extremely fast response is deeply appreciated. I only replaced my files in the system32 and didnt understand why it didnt work after the wow64 files got replaced everything seems fine. Thanks again =]
  10. Posts : 72,046
       #109
    You're most welcome Phantomcide. I'm happy to hear that it seems fine again. :)
