Page 16 of 99 FirstFirst ... 6141516171826 ... LastLast
  1. Posts : 10,200
       #150
    do not know.
    If you have a blue screen problem then:
    post in the Crashes and BSOD forum AND
    follow the procedure there for posting the info they need.
    https://www.sevenforums.com/crashes-d...tructions.html
  2. Posts : 51
    MS Windows 7 64-bit SP1
       #151
    do not see this on my win7dvd anywhere else i can grab it running win 7 x64 pro sp1
  3. Posts : 10,200
       #152
    If in Windows Explorer you select your C drive, and then search on xchalVx64.sys what do you find?
    I do not have that file installed as a driver to be run on my system, although it is part of my Win 7. I also don't use the capabilities of the driver.
    I was afraid of this occurring since \windows\system32 isn't where you find some of the files on your Win 7 DVD, although the end up being installed there.
    Now here's another tidbit of info for you: that msg of a hash mismatch can be caused by the copy in sxs being bad and the copy on your computer being good. Maybe Brink knows the best approach to solve your problem.
  4. Posts : 51
    Windows 7 Pro 64Bit
       #153
    I need some help:
    I read the whole tutorial on using SFC.exe to fix corrupt system files. The bad thing is I think I have over 50. I don't know where to get these files from in the Windows 7 Pro DVD, much less how to put them in the right folders; this seems stupid NOT to have a program to run SFC and parse the c:\windows\Logs\CBS.log to extract the (missing/damaged) file and put it where it needs to. - Donald B.
    SFC /SCANNOW Command - System File Checker Attached Files
  5. Posts : 10,200
       #154
    Did you use one of those wonder "tune Up" programs? There is so much missing from the store, the backup copy that Win 7 automatically keeps for you and then uses when needed, that I suspect the use of a "wonder program".
    Other than the multitude of missing files from the store, does your system have any problems?
    Because unless Brink has some bright ideas, then the only way I see to fix that is a repair install unless you made an image backup before this problem showed up or maybe you are lucky there is a system restore point which will help but I doubt it because system restore depends upon a valid store when it has to restore system files.
  6. Posts : 51
    Windows 7 Pro 64Bit
       #155
    I used some freeware registry programs some time ago; I had a broken WMI component, the only way to fix that was repair install. I use AVG PC Tune Up 2011 it is from the same company who make AVG AV I have used for ages. I ran SFC.exe /scannow and it only repairs three files and shows all files repaired at bottom.
    BTW: I did a REPAIR INSTALL (Run SETUP during Windows running, with out AV) and got a Boot Screen Menu showing Windows 7 (Repaired). I had to change the Boot Menu with BCDEDIT... Pain in the butt.
    Those wonder programs are sometimes crap. I know Windows replaces damaged files it has when it doesn't boot well. If you have any suggestions (a utility that copies all installed programs in Add/Remove List and those in both Program Files(x86) and Program Files, plus those in separate folders with an uninstall###.exe, I would use that to dump this setup and start fresh.
    The Windows 7 Forums consideration for this utility and it's promptness is appreciated.
    Oh well...Repair install here I come...?
    Thanks for the info. Donald
  7. Posts : 19,383
       #156
    Hi,,
    I agree with Karl, unless someone else has a better idea. The best option seems to be a Repair Install.
    Repair Install
    Regards,
    Golden
  8. Posts : 10,200
       #157
    Stop using all of those WONDER programs. The safe ones are listed in my sig.
    I also recommend the best free, in fact, the best AV software, namely, Microsoft Security Essentials. Once again, link in my sig.
    I wish I could stress using MSE enough. MSE is the and the only anti-virus I use and the only anti-virus that I will install on anyone's computer.
  9. Posts : 51
       #158
    any uodate regarding that file karl ? it seems to make me think that this could be the reason for my system issue..btw i have download and installed most of your recommended programs ..Do u ever get blue screens regarding memory
  10. Posts : 10,200
       #159
    I get blue screens once every blue moon and the last one was actually a "feature" of a ms office update which was a once only occurrence so couldn't catch it.
    If you have blue screens still, then I highly recommend the Crashes and Debugging forum or whatever its called. Those chaps are amazing with much experience and knowledge. Follow the instructions there re posting:
