Page 19 of 99 FirstFirst ... 9171819202129 ... LastLast
  1. Posts : 72,062
       #180
    I'm not sure it will work with a "Anytime upgrade", but you would have to use a same retail installation disc as what you currently have installed.
    Ultimate 64-bit in your case if you uninstalled SP1.
    Be sure to backup anything that you do not want to lose first in case it doesn't work though.
  2. Posts : 41
    Windows 7 Ultimate x64-bit SP1
       #181
    Ok Thanks for all the help.
  3. Posts : 72,062
       #182
    You're welcome Kevin. Please let us know how it went. :)
  4. Posts : 41
       #183
    Shawn,
    Could I try this to fix the problem?
    Extract Files from Windows 7 Installation DVD
  5. Posts : 72,062
       #184
    Kevin,
    The problem is that the explorer.exe file will be in use, and cannot be replaced while running Windows 7 with explorer running in it.
    For the amount of trouble it would take to extract the file and copy/replace it from outside of Windows, it would probably be easier to just reinstall.
  6. Posts : 41
       #185
    Ok thanks, I will try the "Repair Install" w/the Anytime Upgrade and let you know about it once I get around to it. Will post the out come on the Repair Install thread.
    Thanks,
    Kevin
  7. Posts : 103
    Was running sfc.scannow. More or less my corrupted files been corrected.
    There is one small thing. How I can back to sound when Windows was start before sfc "operation"? I have .wav file and know that this sound is located in imageres.dll folder.
    Will appreciate help
    Regards
  8. Posts : 72,062
       #187
    Hello Stasioau,
    If you mean the startup sound, then it was restored to default since a SFC /SCANNOW command undoes all modifications to system files and restores them to default. You will just need to do the tutorial below again to change the startup sound again.
    Startup Sound - Change in Windows 7
  9. Posts : 103
    Hi Shawn. Just come back to my computer and see message from you. Thank you very much; I am sure that your tutorials solve my small problems.
    Please accept my best regards,
    stasioau
  10. Posts : 72,062
       #189
    You're most welcome Stasioau. :)
