Page 21 of 99 FirstFirst ... 11192021222331 ... LastLast
  1. Posts : 71,980
       #200
    This is for Vista, but still applies to Windows 7 as well. It'll help explain better what it's for. :)
    What is the WINSXS directory in Windows 2008 and Windows Vista and why is it so large? - Ask the Core Team - Site Home - TechNet Blogs
  2. Posts : 24
    Windows Ultimate x64
       #201
    Hey Brink, thank you for your support here!
    Here's my CBS.log file, as I there were errors Windows couldn't fix just like the user before.
    CBS.log
    Do you recommended reinstalling Windows 7, what are the errors here and what exactly are you looking at to find them out?
    Also, when I try this cmd
    findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >%userprofile%\Desktop\sfcdetails.txt
    My scfdetails.txt in the desktop ends up being empty (0 bytes)
  3. Posts : 71,980
       #202
    Hello Satire, and welcome to Seven Forums.
    Did you run the sfc /scannow command?
    There are no entries in your CBS.log for a SFC scan.
  4. Posts : 24
       #203
    Nope I ran it a few days ago, maybe it deleted the results or something. Just reran it, here you go:
    sfcdetails.txt (looks like it works now, as there's content): sfcdetails.txt
    CBS.log: CBS.log
  5. Posts : 71,980
       #204
    You could upload the files directly instead though.
    2011-10-14 11:45:16, Info                  CSI    000002f8 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2011-10-14 11:45:16, Info                  CSI    000002fa [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2011-10-14 11:45:16, Info                  CSI    000002fb [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
    2011-10-14 11:45:16, Info                  CSI    000002fe [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
    From this, you have a corrupted iassdo.dll.mui file at the location below that cannot be fixed. If you like, you could use the tutorial below to extact a good copy of the iassdo.dll.mui file from your Windows 7 installation disc to replace the corrupted one on your current installation with.
    Extract Files from Windows 7 Installation DVD
  6. Posts : 24
       #205
    Ok I just did that, took ownership of the file so I could overwrite because at first I had a permission problem.
    Reran sfc /scannnow, it's still showing the same error
    SFC /SCANNOW Command - System File Checker Attached Files
  7. Posts : 71,980
       #206
    Unless you are having an issue with language packs, I wouldn't worry about it though.
  8. Posts : 24
       #207
    I see. Well the main reason I was using sfc /scannow is because it was recommended in order to fix an issue I was having with BFBC2. If that .dll.mui file is not related to my issue, then I guess it must be something else. Please a take look at my thread if you have time: https://www.sevenforums.com/crashes-d...ml#post1615766
  9. Posts : 71,980
       #208
    No, I don't think that file would be related to that issue.
  10. Posts : 10,200
       #209
    Shawn,
    what have i done that id do not have a vsp1cln.exe on my computer:
    Service Pack 1 contains a binary called VSP1CLN.EXE, a tool that will make the Service Pack package permanent (not removable) on your system, and remove the RTM versions of all superseded components.
