Page 22 of 99 FirstFirst ... 12202122232432 ... LastLast
  1. Posts : 72,059
       #210
    Hello Karl,
    That file is what is used to run the SP1 disk cleanup tool for Vista. Of course, Vista is on SP2 now though. The link was only to help reference what the winsxs folder is for though.
    For Windows 7, you would want to use the one in the tutorial below instead.
    Windows 7 SP1 Disk Cleanup Tool
  2. Posts : 10,200
       #211
    Shawn, thanks. I knew of the approach in the tutorial but didn't know if I had missed something.
    The link did bring one question to mind:
    When I delete a file for system32 folder them am I really deleting just a link to a sxs file?
  3. Posts : 72,059
       #212
    No, they are not linked to the files in the winsxs folder. They are separate.
  4. Posts : 21,004
       #213
    Problem
    Hiyya Shawn mate I have typed the sfc in the search > click on the highlighted result > the small black screen appears for an instant and then disappears.
    Doesn't matter how many times I did this - same result - problem with my OS?
  5. Posts : 72,059
       #214
    Hello John,
    You would need to open a elevated command prompt first, then type sfc /scannow in the command prompt instead.
  6. Posts : 2
    Windows 7 Ultimate x32
       #215
    Thankyouuu :)
    Brink,
    Thank you very much for the nice, reader-friendly tutorial! I'm so glad I found this article (and forum) after spending many hours of hair-pulling and trying to figure out what was wrong with my laptop. :)
    After checking the CBS.LOG, now I now that the termsrv.dll is corrupted, I assume that's why my laptop freezes after booting. Only the "safe mode" works. I tried running the scannow command several times, but the problem persists. Would you mind giving me some tips to solve it?
    Thanks again for your help! :)
  7. Posts : 72,059
       #216
    Hello Popsky, and welcome to Seven Forums.
    The C:\Windows\System32\termsrv.dll file that is used with "Remote Desktop Sessions". If you do not do remote desktop connections, then I wouldn't worry about trying to fix the file. If you do, then you could do what's in the yellow TIP box at the bottom of the tutorial to extract the termsrv.dllfile from your installation disc to replace it in your current Windows 7 installation at the location(s) specified in the sfcdetails.log file.
    However, I do not believe that this is the cause of your laptop freezing up though. I would recommend that you scan your system with the free programs Malwarebytes (free) and Microsoft Standalone System Sweeper to help make sure that you system is malware/virus free. Afterwards, post all the details about your system freezing in the Crashes and Debugging forum area to see if we may be able to help with this. :)
  8. Posts : 2
       #217
    Oh, thank you for the information and the fast reply! :)
    I did both, replacing the "termsrv" file to the instructed folders and running the Malwarebytes Program. And you're correct! After the Malwarebytes scanned and fixed several problems in my computer, voila! It works just fine now! Now I'm running my computer smoothly, no more freezing up after booting!
    Thank you very much for this, you are a livesaver, seriously.
  9. Posts : 72,059
       #218
    You're most welcome Popsky. I'm very happy to hear that your computer is back up and running fine again. :)
  10. Posts : 150
    windows 7 home premium 64bit
       #219
    I did create short cut and did a scan. "found corrupted file but not able to fix some of them". What do I need to do now ? Thanks.
